SuperLabel exception
Posted by: stenio on 28 October 2019, 5:58 am EST
    Posted 28 October 2019, 5:58 am EST
    I have updated Studio For Winforms to version 4.0.20192.375 but now I am getting an exception either from the designer or the compiled application when in the form there is a SuperLabel, please see an excerpt of the exception below:
    System.Reflection.TargetInvocationException
    HResult=0x80131604
    Messaggio=Eccezione generata dalla destinazione di una chiamata.
    Origine=mscorlib
    Analisi dello stack:
    at System.RuntimeMethodHandle.InvokeMethod(Object target, Object arguments, Signature sig, Boolean constructor)
    at System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Object obj, Object parameters, Object arguments)
    at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object parameters, CultureInfo culture)
    at System.Reflection.RuntimePropertyInfo.SetValue(Object obj, Object value, Object index)
    at System.ComponentModel.ComponentResourceManager.ApplyResources(Object value, String objectName, CultureInfo culture)
    Eccezione interna 1:
    ArgumentException: ‘-1’ non è un valore valido per ‘emSize’. ‘emSize’ deve essere maggiore di 0 e minore o uguale a System.Single.MaxValue.
    Nome parametro: emSize
  • Posted 28 October 2019, 7:06 am EST
    It seems that the issue you observe is related to the one observed here: https://www.grapecity.com/forums/winforms-edition/bug-in-c1superlabel
    Please refer the thread and confirm. Also, note that this issue will be fixed in the future builds.
    In case this is not related to your concern, share a stripped down sample showing the issue. This will help me observe the same and assist you further.
  • Posted 28 October 2019, 11:35 am EST
    Hello Esha,
    Yes the issue seems the same. I am looking forward for the new build.
    Is it possibile to have a nightly build or can you tell me how to reinstall a previous version from the C1Live backup?
    Stenio
  • Posted 30 October 2019, 1:55 am EST - Updated 4 October 2022, 12:37 am EST
    Hello Stenio,
    You can use ControlPanel (download it from here: https://cdn.grapecity.com/ComponentOne/2019v2/ComponentOneControlPanel20192.1.16.exe) and select a specific version to be installed on your machine from the Version dropdown under a particular edition.
    Regards.
