Posted 15 August 2018, 9:03 am EST
how can I Determine if a column (say the column name is xxx) in tdbg exists?
Something like that:
if tdbg1.columns(“xxx”).exist then …
Thank you in advance.
Posted by: edv on 15 August 2018, 9:03 am EST
Posted 16 August 2018, 1:38 am EST
There is no method to directly check for existence of a column.
If you try to access a column that does not exist then ArgumentException is thrown.
You can easily add an Extension method called Exists to check if a column exists in the grid.
Please find the attached sample to see how you can add this extension method.
Regards.
Posted 17 August 2018, 12:49 am EST
Here’s an alternative solution that doesn’t require extension method:
Dim isExistAll = _trueDB.Columns.Cast(Of C1DataColumn).Any(Function(x) x.Caption = "1234" OrElse x.DataField = "1234")
For DisplayColumns in a specific split:
Dim IsExistDisplay = _trueDB.Splits(0).DisplayColumns.Cast(Of C1DisplayColumn).Any(Function(x) x.DataColumn.Caption = "1234" OrElse x.DataColumn.DataField = "1234")
Regards.
Posted 20 August 2018, 6:47 am EST
Thank you very much.
Posted 20 August 2018, 6:50 am EST
Now I am using
If tdbg1.DataSource.Columns("xxx") Is Nothing Then Exit Sub
and it works for me!
