The problem of placing two or more Ribbon controls inside other elements
Posted by: icevldg on 5 March 2018, 10:17 am EST
    Posted 5 March 2018, 10:17 am EST
    Hello!
    When you place the Ribbon control inside the tab bar on the same form, when you compile the project, an error is reported in the property “this.c1Ribbon2.ApplicationMenuHolder = this.ribbonApplicationMenu2” text “System.ApplicationException:” The ApplicationMenu has already been assigned. “”. You can reproduce this error by annotating the property. But when the code is auto-generated, the problem is repeated. The problem is found in version 4.0.20173.286.
    I assume the problem occurs after updating the Ribbon control in the "C1.Win.C1Ribbon
    Bug fixes
    RibbonAppMenuTab did not apply a backcolor of control to the tab area.
    Corners of C1RibbonForm were rounded when set VisualStyle was Custom. (TFS: 286774)
    Improvements
    Added new RibbonAppMenuTab component for RibbonAppMenu. This component can host a Control. "
    I ask you, help to cope with this situation. Thank you!
    P.S. Please do not scold me for the correctness of the translation.
  • Posted 6 March 2018, 2:39 am EST
    This is a known issue with 286 builds and has been fixed in a build that would be released by end of March.
    Let us know if you need any further assistance.
  • Posted 14 March 2018, 5:50 am EST
    This issue is fixed with the latest 2018v1 builds. You can use C1Live to upgrade to the same.
    Let us know if you need further assistance.
