Treeview theme problem . . more detail
Posted by: kbj on 17 November 2017, 6:12 pm EST
    Posted 17 November 2017, 6:12 pm EST
    When a user changes a theme, the themed treeview hot background paints using the color of the previous theme’s C1TreeView\Palette\Colors\ControlBackColor path
    In this example the theme was changed from Office2013HighContrast to Office2010Blue
    Since themed backgrounds are frequently brushes, intercepting ApplyNodeStyles wont help.
    Many themes C1TreeView\TreeViewStyles\Hot\BackBrush background brushes are transparent, yet backrounds are painted slightly greyed.
    Is there a way to force nodes to display properly once the theme is changed? None of the
    Kingman
    PS Any news on the Sluggish Treeview With Only 300 Nodes problem? (I get the feeling it has to do with storing images in a treelist which used to slow down the Ribbon Menu and Tabs controls) It would be great to directly set the images used by the checkboxes and expand collapse.
  • Posted 20 November 2017, 8:38 am EST
    We could not observe both the issues at our end using 4.0.20173.282. If you are using any older version ,we suggest you to please update using C1Live. If still the issues occurs, could you please modify the uploaded application, so that we could test at our end and help you further: https://www.dropbox.com/s/vjglimtp1muk7zy/TreeViewStyle.zip?dl=0
    Also, regarding slow loading of C1TreeView, the development team is currently working over this case. We will update you once it is updated.
    Ruchir Agarwal
