True Db Grid winforms edition grid column order
Posted by: kshitizkumar on 13 June 2019, 3:14 am EST
    Posted 13 June 2019, 3:14 am EST
    I am working on a migration project from vb6 to c#.net
    In vb6 version of the application truedb grid activeEX version was used and in the .net application we are using winforms edtition of the grid.
    In the active X version to determine the column positions we used order property of the grid (very handy).
    But, in the winforms edition I could not find the Order property or property that provide similar functionality.
    Is there a way to achieve same functional equivalence as Order property from Active X version in the winforms edition ?
    Any suggestion will be helpful.
    Kshitiz
  • Posted 13 June 2019, 6:38 am EST
    Hi Kshitiz,
    You can use the IndexOf method of DisplayColumns:
    var column = c1TrueDBGrid1.Columns["ColName"];
    int displayIndex = c1TrueDBGrid1.Splits[0].DisplayColumns.IndexOf(column);
    See attached sample for complete example.
    ColumnPosition.zip
    Jitender
