Posted 21 September 2021, 1:05 pm EST
I need some help
when enter data in true dbgrid row cell and then move to one cell to another cell. remove data from previous cell showing blank cell.
how to solve these type of problem
Thank you
Posted by: ribscorporation on 21 September 2021, 1:05 pm EST
I need some help
Thank you
Posted 22 September 2021, 5:03 am EST
We do not see the issue at our end, as shown in the attached GIF. If you are doing anything else, then please let us know and modify the sample accordingly.
TDBDataDemo.zip
Posted 23 September 2021, 5:58 am EST
couldn’t open these file because dll missing
Unable to resolve type c1.win.c1truedbgrid.c1.win.c1truedbgrid,c1.win.c1truedbgrid.4.5.2
Posted 23 September 2021, 6:01 am EST
unable adding value in true dbgrid cell if enter value in cell it’s showing the value when leave the cell to other it will remove previous cell value
Posted 23 September 2021, 6:10 am EST
unable adding value in true dbgrid cell if enter value in cell it’s showing the value when leave the cell to other it will remove previous cell valueNew folder.zip
Posted 23 September 2021, 6:20 am EST
please check the attached file New folder.zip
Posted 24 September 2021, 6:05 am EST
Do you face the same issue with our attached sample?
If not, then please modify it accordingly so that we can assist you further with the resolution.
Posted 24 September 2021, 10:43 pm EST
I not getting right answer or right solution
Posted 28 September 2021, 6:37 am EST
As per your comments, it seems that you are using the TrueDBGrid in Unbound mode. If yes then please set the SetDataBinding before loading the form.
c1TrueDBGrid1.SetDataBinding();
If you are still facing the issue then please modify the last attached sample so that we can modify it accordingly as per your need.
