True DBGrid Show Column Totals
Posted by: sarosh.wadia on 17 October 2017, 11:33 am EST
    Posted 17 October 2017, 11:33 am EST
    Hi!
    I am using the C1TrueDBGrid in a WinForms App (C1 WinForms 4.0) and want to display Totals for Columns in the grid. I have set the Aggregate to Count/Sum for each column as required and have also set the grids ColumnFooters to true.
    I can see the ColumnFooter Row but none of the Columns are showing their counts, sums etc.
  • Posted 18 October 2017, 1:00 am EST
    Hello!
    Please refer to the ‘AggreGateFooter’ in the ComponentOne samples installed along with the product, at the given location on your machine:
    \Documents\ComponentOne Samples\WinForms\C1TrueDBGrid\CS\AggreGateFooter
    In case you need any further assistance, you can let me know.
    Meenakshi
  • Posted 18 October 2017, 10:51 am EST
    Hi!
    I went through the code in the “AggreGateFooter” solution and saw that the “BindingListChanged” event calls _calcFooter() which manually loops through all the rows in the grid to get the total and then stores that in the columns FooterText.
    The grid has a few thousand rows and users are adding/deleting, filtering this data all the time. Are you telling me that I have to manually recalculate (about 15 columns) all the column totals each time they add/edit/delete/filter the data?
    What’s the point of setting the Aggregate to Count/Sum for each column if I have to manually loop through all the grid rows and set the FooterText?
    Shouldn’t this be handled automatically by the grid once you set the Aggregate for a column?
    I’m hoping there is a better way than this or am I missing something!
  • Posted 23 October 2017, 7:06 am EST
    Hi!
    Sorry to mention that there is no other way possible for doing this, at the moment. However, you can try something like this with C1FlexGrid also, if possible.
    C1FlexGrid provides Subtotal method that can show aggregates without looping through all rows. Kindly refer to the ‘Subtotals’ in ComponentOne samples, installed along with the product, at the given location on your machine:
    \Documents\ComponentOne Samples\WinForms\C1FlexGrid\CS\Subtotals
    Meenakshi
  • Posted 23 October 2017, 12:42 pm EST
    Hi!
    I found a way to get the Column Totals using GroupedCoumns in the C1TrueDBGrid but Can I show this group total at the Bottom of the data instead of the the Top?
    something similar to the FlexGrid’s SubtotalPosition = SubtotalPositionEnum.BelowData
  • Posted 24 October 2017, 5:03 am EST
    Hello!
    You can set GroupInfo.Position property of each column to ‘Footer’ value. Attached is a small sample for your reference.
    Meenakshi
    Prj_SummaryRowPosition.zip
  • Posted 25 October 2017, 3:24 pm EST
    Hi!
    That worked!
