Posted 25 January 2018, 9:18 am EST
I have noticed on 2016+ builds of C1, that the TrueDBGrid no longer trims string fields when bound to a Datatable, which makes string fields which are center aligned, both not center aligned, and included the ellipses as if there is more of the string to be displayed. I know I can work around this using OwnerDraw if necessary, but I was hoping there was a simpler solution, maybe a property of the grid that can be set so that the behaviour dealing with string fields is to trim the contents before they are drawn in the cells.
