Upgrade route from version 2.0.20071.61115
Posted by: kent.ulyatt on 9 May 2023, 12:18 pm EST
  • Posted 9 May 2023, 12:18 pm EST
    Is there an upgrade route from vb2005.net using vesion
    2.0.20071.61115 to a VB2010.net ?
  • Posted 10 May 2023, 4:36 am EST
    Could you please let us know which of the C1 control you are using? and of which version? Also, let us know the technology are using, ActiveX or WinForms? Do you want to convert from 2005 to 2010 of C1 controls?
    FYI, the basic upgrade steps are
    1. Remove the C1 DLL references of the old version
    2. Add the C1 DLL references of the required version.
    3. Update the assembly names in the entries of the licenses.licx file.
    4. If you are upgrading from a very old to a newer version, there might be some changes in code that you will need to cater to manually.
    Thanks, and Kind Regards,
