Posted 21 February 2018, 9:48 am EST
I’ve added a vsflex8l ocx to my visualstudio 2015 c# project on a 64bit windows 7 machine.
Made a reference with no problem.
When trying to drag the object to the form - it doesnt show it.
The project compiles… and runs but the grid is not visible in the form.
I am attaching here code from a tool named:
PROCESSACTIVITYVIEW with shows all the files used by a process.
please help me find the “bad guy” how prevents the object to be shown.
Index : 1
Filename : C:\Windows\Microsoft.NET\Framework\v4.0.30319\clr.dll
Extension : dll
Open Count : 3
Close Count : 4
Failed Count : 0
Read Count : 0
Write Count : 0
Read Bytes : 0
Write Bytes : 0
Last Handle : 0x00000054
Last Error Code :
Opened By Module :
Opened By Address : 0x00000000
Index : 2
Filename : C:\Debug\WindowsFormsApplication6.exe.config
Extension : config
Open Count : 5
Close Count : 5
Failed Count : 0
Read Count : 10
Write Count : 0
Read Bytes : 57,272
Write Bytes : 0
Last Handle : 0x00000298
Last Error Code :
Opened By Module :
Index : 3
Filename : C:\Windows\Microsoft.NET\Framework\v4.0.30319\config\machine.config
Extension : config
Open Count : 3
Close Count : 3
Failed Count : 0
Read Count : 19
Write Count : 0
Read Bytes : 106,924
Write Bytes : 0
Last Handle : 0x0000022c
Last Error Code :
Opened By Module :
Index : 4
Filename : C:\Windows\Globalization\Sorting\sortdefault.nls
Extension : nls
Open Count : 1
Close Count : 1
Failed Count : 0
Read Count : 0
Write Count : 0
Read Bytes : 0
Write Bytes : 0
Last Handle : 0x0000015c
Last Error Code :
Opened By Module :
Index : 5
Filename : C:\Windows\assembly\NativeImages_v4.0.30319_32\mscorlib\225759bb87c854c0fff27b1d84858c21\mscorlib.ni.dll.aux
Extension : aux
Open Count : 1
Close Count : 1
Failed Count : 0
Read Count : 1
Write Count : 0
Read Bytes : 176
Write Bytes : 0
Last Handle : 0x000001c8
Last Error Code :
Opened By Module :
Index : 6
Extension : exe
Open Count : 1
Close Count : 1
Failed Count : 0
Read Count : 0
Write Count : 0
Read Bytes : 0
Write Bytes : 0
Last Error Code :
Opened By Module :
Index : 7
Filename : C:\Windows\assembly\pubpol478.dat
Extension : dat
Open Count : 1
Close Count : 0
Failed Count : 0
Read Count : 0
Write Count : 0
Read Bytes : 0
Write Bytes : 0
Last Handle : 0x000001fc
Last Error Code :
Opened By Module :
Index : 8
Filename : C:\Windows\assembly\NativeImages_v4.0.30319_32\System.Windows.Forms\f225aa7e67afcc6b6c9ed91178cb710c\System.Windows.Forms.ni.dll.aux
Extension : aux
Open Count : 1
Close Count : 1
Failed Count : 0
Read Count : 1
Write Count : 0
Read Bytes : 1,720
Write Bytes : 0
Last Handle : 0x00000204
Last Error Code :
Opened By Module :
Index : 9
Filename : C:\Windows\assembly\NativeImages_v4.0.30319_32\System\1a47631c947cd61eae1f4ebf9c20ed46\System.ni.dll.aux
Extension : aux
Open Count : 1
Close Count : 1
Failed Count : 0
Read Count : 1
Write Count : 0
Read Bytes : 620
Write Bytes : 0
Last Handle : 0x00000208
Last Error Code :
Opened By Module :
Index : 10
Filename : C:\Windows\assembly\NativeImages_v4.0.30319_32\System.Drawing\3bc546fe7b56840164b6f004cab9b859\System.Drawing.ni.dll.aux
Extension : aux
Open Count : 1
Close Count : 1
Failed Count : 0
Read Count : 1
Write Count : 0
Read Bytes : 584
Write Bytes : 0
Last Error Code :
Opened By Module :
Index : 11
Filename : C:\Windows\Microsoft.NET\Framework\v4.0.30319\SortDefault.nlp
Extension : nlp
Open Count : 1
Close Count : 1
Failed Count : 0
Read Count : 0
Write Count : 0
Read Bytes : 0
Write Bytes : 0
Last Handle : 0x00000228
Last Error Code :
Opened By Module :
Index : 12
Filename : C:\Windows\assembly\NativeImages_v4.0.30319_32\System.Configuration\50d832a27c61581516d4f79b7af3bbd3\System.Configuration.ni.dll.aux
Extension : aux
Open Count : 1
Close Count : 1
Failed Count : 0
Read Count : 1
Write Count : 0
Read Bytes : 864
Write Bytes : 0
Last Error Code :
Opened By Module :
Index : 13
Filename : C:\Windows\assembly\NativeImages_v4.0.30319_32\System.Core\39f1280771fd2ab0a893329579bf6497\System.Core.ni.dll.aux
Extension : aux
Open Count : 1
Close Count : 1
Failed Count : 0
Read Count : 1
Write Count : 0
Read Bytes : 900
Write Bytes : 0
Last Handle : 0x00000230
Last Error Code :
Opened By Module :
Index : 14
Filename : C:\Windows\assembly\NativeImages_v4.0.30319_32\System.Xml\526bc514e6559ee6e7005c22662307c8\System.Xml.ni.dll.aux
Extension : aux
Open Count : 1
Close Count : 1
Failed Count : 0
Read Count : 1
Write Count : 0
Read Bytes : 748
Write Bytes : 0
Last Error Code :
Opened By Module :
Index : 15
Filename : C:\Debug\AxInterop.VSFlex8L.dll
Extension : dll
Open Count : 2
Close Count : 1
Failed Count : 0
Read Count : 0
Write Count : 0
Read Bytes : 0
Write Bytes : 0
Last Handle : 0x0000024c
Last Error Code :
Opened By Module :
Index : 16
Filename : C:\Windows\system32\rsaenh.dll
Extension : dll
Open Count : 1
Close Count : 1
Failed Count : 0
Read Count : 0
Write Count : 0
Read Bytes : 0
Write Bytes : 0
Last Handle : 0x00000270
Last Error Code :
Opened By Module :
Index : 17
Filename : C:\Debug\Interop.VSFlex8L.dll
Extension : dll
Open Count : 2
Close Count : 1
Failed Count : 0
Read Count : 0
Write Count : 0
Read Bytes : 0
Write Bytes : 0
Last Handle : 0x00000290
Last Error Code :
Opened By Module :
Index : 18
Filename : C:\Windows\Microsoft.NET\Framework\v4.0.30319\mscorrc.dll
Extension : dll
Open Count : 1
Close Count : 1
Failed Count : 0
Read Count : 0
Write Count : 0
Read Bytes : 0
Write Bytes : 0
Last Error Code :
Opened By Module :
Index : 19
Filename : C:\Windows\system32\OLEACCRC.DLL
Extension : DLL
Open Count : 1
Close Count : 1
Failed Count : 0
Read Count : 0
Write Count : 0
Read Bytes : 0
Write Bytes : 0
Last Handle : 0x000002c4
Last Error Code :
Opened By Module :
Index : 20
Filename : c:\netbios\system32\VSFLEX8L.OCX
Extension : OCX
Open Count : 1
Close Count : 0
Failed Count : 0
Read Count : 18
Write Count : 0
Read Bytes : 362
Write Bytes : 0
Last Handle : 0x000002d8
Last Error Code :
Opened By Module :
Index : 21
Filename : C:\Users\utyol02\AppData\Local\GDIPFONTCACHEV1.DAT
Extension : DAT
Open Count : 1
Close Count : 1
Failed Count : 0
Read Count : 0
Write Count : 0
Read Bytes : 0
Write Bytes : 0
Last Handle : 0x000002f4
Last Error Code :
Opened By Module :
Index : 22
Filename : C:\WINDOWS\FONTS\TAHOMA.TTF
Extension : TTF
Open Count : 3
Close Count : 3
Failed Count : 0
Read Count : 0
Write Count : 0
Read Bytes : 0
Write Bytes : 0
Last Error Code :
Opened By Module :
Index : 23
Filename : C:\WINDOWS\FONTS\MSJH.TTF
Extension : TTF
Open Count : 3
Close Count : 3
Failed Count : 0
Read Count : 0
Write Count : 0
Read Bytes : 0
Write Bytes : 0
Last Error Code :
Opened By Module :
Index : 24
Filename : C:\WINDOWS\FONTS\MSYH.TTF
Extension : TTF
Open Count : 3
Close Count : 3
Failed Count : 0
Read Count : 0
Write Count : 0
Read Bytes : 0
Write Bytes : 0
Last Error Code :
Opened By Module :
Index : 25
Filename : C:\WINDOWS\FONTS\MALGUN.TTF
Extension : TTF
Open Count : 3
Close Count : 3
Failed Count : 0
Read Count : 0
Write Count : 0
Read Bytes : 0
Write Bytes : 0
Last Error Code :
Opened By Module :
Index : 26
Filename : C:\WINDOWS\FONTS\MICROSS.TTF
Extension : TTF
Open Count : 3
Close Count : 3
Failed Count : 0
Read Count : 0
Write Count : 0
Read Bytes : 0
Write Bytes : 0
Last Error Code :
Opened By Module :
Index : 27
Filename : C:\WINDOWS\FONTS\SEGOEUI.TTF
Extension : TTF
Open Count : 3
Close Count : 3
Failed Count : 0
Read Count : 0
Write Count : 0
Read Bytes : 0
Write Bytes : 0
Last Error Code :
Opened By Module :
Index : 28
Filename : C:\Windows\SysWOW64\stdole2.tlb
Extension : tlb
Open Count : 1
Close Count : 0
Failed Count : 0
Read Count : 15
Write Count : 0
Read Bytes : 242
Write Bytes : 0
Last Handle : 0x000002f8
Last Error Code :
Opened By Module :
Index : 29
Filename : C:\Windows\assembly\NativeImages_v4.0.30319_32\Accessibility\44a4ab91e8e11c7cb95343e2d9ffe621\Accessibility.ni.dll.aux
Extension : aux
Open Count : 1
Close Count : 1
Failed Count : 0
Read Count : 1
Write Count : 0
Read Bytes : 276
Write Bytes : 0
Last Error Code :
Opened By Module :
Index : 30
Filename : C:\Windows\Microsoft.Net\assembly\GAC_MSIL\Accessibility\v4.0_4.0.0.0__b03f5f7f11d50a3a\Accessibility.dll
Extension : dll
Open Count : 4
Close Count : 3
Failed Count : 0
Read Count : 0
Write Count : 0
Read Bytes : 0
Write Bytes : 0
Last Handle : 0x000002e4
Last Error Code :
Opened By Module :
Thnx.
