What is C1.Common.dll? & Where can I get it?
Posted by: i on 22 December 2017, 2:28 am EST
    Posted 22 December 2017, 2:28 am EST
    Currently I got a job to update a 10 years old project which using C1.FlexGrid & C1.Common dll’s. That project shows error status C1.Common.dll missing. I couldn’t find out C1.Common library in project source or anywhere in our system. Where can I get it?
    Anyone please help
  • Posted 26 December 2017, 4:53 am EST
    Hi!
    Please note that this assembly is the supporting file for 1.x version of the ComponentOne Controls and you will not get it in the 2.x or higher versions because this file is no more used by the higher version of the controls.
    In the modern .NET 2.0 and .NET 4.0 controls, it has been removed.
    In case you are not able to run your older project after upgrading, could you please share back your observations (along with a screenshot)? Please make sure, you clean and rebuild your project.
    Best regards,
    Meenakshi
