Posted 13 September 2018, 1:18 pm EST
Spread 3 COM had Index property and I am looking for equivalent property in spread version 8.
Posted by: adarshab039 on 13 September 2018, 1:18 pm EST
Posted 14 September 2018, 12:11 am EST
You can use Control.ControlCollection.GetChildIndex & Control.ControlCollection.SetChildIndex in Spread.Net for equivalent of Spread 3 COM’s index property.
Please go through these documentation links for the same:-
http://help.grapecity.com/spread/SpreadNet11/WF/webframe.html#spwin-comprops.html
http://help.grapecity.com/spread/SpreadNet11/WF/webframe.html#spwin-comequivalents.html
Hope it helps.
Reeva
Posted 15 September 2018, 11:31 am EST
Hi Would you please let me know how implement the same. The below mentioned implementation sounds correct to you?
Dim child As Control
sprIn As AxFPSpreadADO.AxfpSpread
sprIn.Controls.GetChildIndex(child)
Please let me know if I am wrong
Posted 17 September 2018, 12:36 am EST
You want to implement the index property of Spread COM version 3 in Spread COM version 8 or Spread .Net version 8. Please specify the platform. We will answer your issue accordingly.
Reeva
Posted 18 September 2018, 9:45 am EST
Would anyone please reply, I want to implement using Spread COM version 8.
Posted 19 September 2018, 3:37 am EST
Since you are trying to use Spread COM 8 in .Net Winforms application. Hence, you cannot use index property as Index property works for COM controls in ActiveX environment i.e. VB6 and not for COM components in .Net environment.
And even GetChildIndex() method won’t work here because it is meant for controls .Net technology.
Further it is also not advisable to use Spread COM in .Net managed environment. Hence, we request you to switch to Spread.Net for .Net Winforms application.
You can download the same from this link:-
https://www.grapecity.com/en/download/spreadnet
Hope it clarifies.
Reeva
Posted 27 September 2018, 5:38 pm EST
Hi Reeva,
I contacted your support team and they suggested me to use spread 8 for dot net as it is a backward compatibility. Now would you please tell me how to implement index property in spread 8.
AB
Posted 28 September 2018, 12:41 am EST
Index (standard Visual Basic property) of Spread COM can be implemented in Spread.Net using below mentioned GetChildIndex & SetChildIndex property as stated in first post also:-
Hope it helps.
Reeva
