What is the spread 3 Index property equivalent in spread 8
Posted by: adarshab039 on 15 September 2018, 11:38 am EST
    Posted 15 September 2018, 11:38 am EST
    Hi, I got to know that below mentioned is the equivalent in version 8 for the Index property which was present in Version 3
    Index (standard Visual Basic property)
    Control.ControlCollection.GetChildIndex
    Control.ControlCollection.SetChildIndex
    As per the above, I have implemented like as mentioned below.
    Dim child As Control
    sprIn As AxFPSpreadADO.AxfpSpread
    sprIn.Controls.GetChildIndex(child)
    Please let me know if I am wrong
  • Posted 17 September 2018, 12:36 am EST
    You want to implement the index property of Spread COM version 3 in Spread COM version 8 or Spread .Net version 8. Please specify the platform. We will answer your issue accordingly.
    Reeva
  • Posted 17 September 2018, 9:45 am EST
    I want to implement using Spread COM 8.Would you help me please?
  • Posted 19 September 2018, 3:37 am EST
    Since you are trying to use Spread COM 8 in .Net Winforms application. Hence, you cannot use index property as Index property works for COM controls in ActiveX environment i.e. VB6 and not for COM components in .Net environment.
    And even GetChildIndex() method won’t work here because it is meant for controls .Net technology.
    Further it is also not advisable to use Spread COM in .Net managed environment. Hence, we request you to switch to Spread.Net for .Net Winforms application.
    You can download the same from this link:-
    https://www.grapecity.com/en/download/spreadnet
    Hope it clarifies.
    Reeva
