Winforms Control Explorer
Posted by: cnoelle on 30 June 2022, 4:26 am EST
    Posted 30 June 2022, 4:26 am EST
    All chart demos inherit from C1DemoForm, where is the code?
  • Posted 1 July 2022, 1:40 am EST
    The complete Source code of the WinForms ControlExplorer sample is available at the location
    [b]\Documents\ComponentOne Samples\WinForms\v4.5.2\WinForms\CS\ControlExplorer[/b] in your system.
    The C1DemoForm class can be found at the location [b]\Documents\ComponentOne Samples\WinForms\v4.5.2\WinForms\CS\ControlExplorer\Main[/b]
    Kind Regards,
  • Posted 4 July 2022, 11:12 am EST
    Thanks, does not run either, “license problems…”
    Also I could not find any RotateEventArgs, where did they go?
  • Posted 5 July 2022, 7:47 am EST
    The sample is working fine at our end. Could you please let us know what kind of license problem are you facing, or share some screenshots showing the issue, so we can assist you better?
    Also, the RotateEventArgs are available in the C1Chart3D API and not the FlexChart. Is there any specific functionality are you looking for in the FlexChart?
    Kind Regards,
  • Posted 6 July 2022, 2:04 am EST
    I have Winforms Edition license, so missing flexPivot…
    Controlexplorer project does not compile.
    I am using C1Chart3D and looking for the rotate events. How can I watch rotation events?
  • Posted 6 July 2022, 7:53 am EST
    Yes, you are right that the FlexPivot requires a C1 Enterprise Edition license. Sorry for the confusion.
    To watch the rotation events, you can handle the BeforeRotate and AfterRotate events of the Chart3DView class. Please refer to the attached sample showing a simple implementation of the same.
    Sample_C1Chart3D.zip
    Kind Regards,
  • Posted 7 July 2022, 9:47 am EST
    Thanks, Kartik.
    Hard to find in the help…
    Chris
