Posted 27 June 2022, 12:03 am EST
A similar issue related to the AutoSizeRows method of the C1FlexGrid has been fixed in the latest 2022v1(557) hotfix release. Please try to run your application with this version and see if you still face the issue. You can update to the latest hotfix version by using either the ComponentOne Control Panel OR by directly installing the NuGet package from the link below.
C1 Control Panel:
In the Control Panel,
- Go to PRODUCTS > BUILD REPOSITORY tab
- Check the Include prerelease and hotfix versions checkbox
- Expand the WinForms Edition node.
- Click the update button for the required .NET framework.
- Click the Update to latest version option.
- Click the UPDATE button.
NuGet:
https://www.nuget.org/packages/C1.Win.C1FlexGrid/4.5.20221.557
If the issue persists, please share a small sample showing the Data you are using in the Grid cells(that shows the issue), as the AutoSizeRows method can show different behavior for different types of data/characters. It would help us to investigate the issue further.
Kind Regards,
