Posted 18 January 2022, 9:29 am EST
when i filter the rows of my flexgrid via a filterrow with text. I get the wrong DataIndex from this rows. With the filtering via dropdown filter the dataindex is correct.
Posted by: lars.seehaus on 18 January 2022, 9:29 am EST
Posted 19 January 2022, 7:36 am EST
The FilterRow sample uses the Dataview.RowFilter property to filter the rows, which creates a new DataView of only filtered rows which results in DataIndex values of the filtered rows not being the same as when the Grid is filtered using the DropDown filter. If you want to find the DataIndex of the filtered rows using the FilterRow, you can use the IndexOf method of the source DataTable. Kindly refer to the attached sample.
Avnish
