XLSheet: Maximum number of rows exceeded (65.536)
Posted by: topran on 21 January 2020, 10:25 am EST
    Posted 21 January 2020, 10:25 am EST
    I am using C1XLBook to fill values in a XLSheet.
    With:
                    For Each obj As String In list
                        row = row + 1
                        sheet(row, 0).Value = obj
                    Next
    If the row over 65536, I get this error message:
    Maximum number of rows exceeded (65.536). bei C1.C1Excel.XLRowCollection.Insert(Int32 index, XLRow row)
    bei C1.C1Excel.XLSheet.get_Item(Int32 rowIndex, Int32 colIndex)
    I think it is the same problem as here:
    https://www.grapecity.com/forums/winforms-edition/flexpreview-export-to-exce#original-post
    Is this correct?
    Best wishes
    Jennifer
  • Posted 22 January 2020, 1:52 am EST
    Hi Jennifer,
    By default the C1XLBook object treats the excel as 2003 excel file format if not specified and 2003 excel format has restriction of 256 columns and 65536 rows.
    To solve this you need to first save the C1XLBook object to a OpenXML format i.e. .xlsx and then load it back and start adding rows over 65536. Code snippet is given below :
    int i;
    c1XLBook1.Save(@"..\..\demo.xlsx");
    c1XLBook1.Load(@"..\..\demo.xlsx");
    C1.C1Excel.XLSheet sheet = c1XLBook1.Sheets[0];
    for (i = 0; i <= 66000; i++)
     sheet[i, 0].Value = (i + 1) * 10;
     sheet[i, 1].Value = (i + 1) * 100;
     sheet[i, 2].Value = (i + 1) * 1000;
    Please go through the attached sample demonstrating the same.
    ExcelDemo.zip
  • Posted 23 January 2020, 4:23 am EST
    Hello Prabhat Sharma,
    thanks for your answer it works fine.
    Jennifer
  • Posted 14 December 2020, 11:49 am EST
    Hello
    for everyone with the same problem, I’ve found a good solution.
    Uses the property: ```
    CompatibilityMode = CompatibilityMode.Excel2007
