Add controls in DockTabItem ToolBar
Posted by: vinothkumar.r2210 on 9 May 2020, 12:35 pm EST
    Posted 9 May 2020, 12:35 pm EST
    I am new to ComponentOne DockTabItem. I want to add controls in toolbar of DockTabItem. I tried to edit the template but I can’t find where the existing controls of toolbar exists and not able to add new controls. Please suggest how to accomplish this.
    Thanks and Regards,
    Vinoth Kumar Ravi
  • Posted 11 May 2020, 7:22 am EST
    Hello Vinoth,
    As I understand, you wish to customize the header section of C1DockTabItem, where the menu, dock, and close button are available. If that is so, you should modify the C1DockTabItem.HeaderTemplate property and assign a DataTemplate will any list of controls in it.
    Additionally, I would suggest you to take a look at the default template of the control which is installed here: C:\Program Files (x86)\ComponentOne\WPF Edition\C1WPFDocking.4.5.2\XAML. Referring this, you should be able to learn more about the layout of the control .
    With best regards,
    Ruchir
  • Posted 11 May 2020, 10:34 am EST
    Hi Ruchir,
    Thanks for the reply. I have tried editing the ControlTemplate of DockControl instead of editing the DockTabItem ControlTemplate. I can able to add controls inside that headercontainer. I will also try the above mentioned sample.
    Thanks and Regards,
    Vinoth Kumar Ravi
