Avoiding mousewheel scrolling on ComboBox located inside DataGridTemplateColumn
Posted by: Swapnil.Walwadkar on 14 June 2023, 4:50 am EST
  • Posted 14 June 2023, 4:50 am EST - Updated 14 June 2023, 4:55 am EST
    We are facing one issue and need your support on the same.
    We have a C1DataGrid and inside that we have DataGridTemplateColumn. To that column, we have a ComboBox. Below is the screenshot of xaml. (Image1.png).
    when the user changes the value from the dropdown we get our task done correctly on the selection changed event. (Image2.png)
    Our issue is when the user scrolls the mouse wheel on ComboBox, the value in ComboBox changes which we don’t want to happen.
    We are not able to handle the MouseWheel event for ComboBox as it is giving compile time error of using EventSetter. We also tried creating EventSetter under style but its associated Handler is not getting fired.
    Could you please guide us on how to avoid mouse wheel scrolling on ComboBox located inside DataGridTemplateColumn?
  • Posted 15 June 2023, 6:26 am EST
    Hi Swapnil,
    Unfortunately, we could not replicate the issue on our end. We have attached a sample application for your reference. Please check DatagridCmbBoxTemplate.zip
    We request you share the updated version of the attached sample or provide a stripped-down version of the sample application that replicates the issue on your end. This will help us analyze the issue better and provide you with a more specific solution for this issue. In addition to this, please confirm that you are working with the latest version of C1 controls.
    Thanks & Regards,
    Aastha
