Posted 13 September 2023, 4:01 am EST
I want to bind FlexChart to a series collection in my viewmodel, not define them in markup or in codebehind. Is this possible?
Forums Home / ComponentOne / WPF Edition
Posted by: lpedersen on 13 September 2023, 4:01 am EST
Posted 14 September 2023, 2:59 am EST
Hi Lars,
As per our understanding you want to bind your FlexChart control to the series collection defined in the view model of the project.
We have created a view model containing two series collection with Point type data. Here is the code snippet for the same:
public class ChartViewModel
public ObservableCollection<Point> Series1Data { get; }
public ObservableCollection<Point> Series2Data { get; }
public ChartViewModel()
Series1Data = new ObservableCollection<Point>
new Point { X = 1, Y = 10 },
new Point { X = 2, Y = 20 },
new Point { X = 3, Y = 25 },
// Add more data points for Series 1
Series2Data = new ObservableCollection<Point>
new Point { X = 1, Y = 15 },
new Point { X = 4, Y = 18 },
new Point { X = 7, Y = 30 },
// Add more data points for Series 2
Now, you can bind these collections to your FlexChart control in the View (XAML code) as shown below:
<Window.DataContext>
<local:ChartViewModel/>
</Window.DataContext>
<Grid>
<c1:FlexChart Name="flexchart" ChartType="LineSymbols" BindingX="X">
<c1:FlexChart.Series>
<c1:Series SeriesName="Series A" Binding="Y" ItemsSource="{Binding Series1Data}"/>
<c1:Series SeriesName="Series B" Binding="Y" ItemsSource="{Binding Series2Data}"/>
</c1:FlexChart.Series>
</c1:FlexChart>
</Grid>
Kindly refer to the attached sample for implementation. (See FlexchartMVVM.zip)
Please let us know if you need any further help regarding this.
Thanks & Regards,
Aastha
Posted 14 September 2023, 3:27 am EST
Thank you for the answer, however what I’m after is a collection of series, like:
public ObservableCollection<List<Point>> SeriesCollection { get; }
Posted 15 September 2023, 2:09 am EST
Hi Lars,
Thanks for providing a more detailed information of your use-case.
If you have a collection of Series in your View-Model then you can create series by handling FlexChart’s Loaded event as shown in the following code-snippet via code-behind:
private void flexchart_Loaded(object sender, RoutedEventArgs e)
if (DataContext is ChartViewModel viewModel)
// Add series to the FlexChart control
foreach (var seriesData in viewModel.SeriesCollection)
var series = new Series()
ItemsSource = seriesData,
Binding = "Y",
BindingX = "X"
flexchart.Series.Add(series);
Kindly refer to the attached sample for full implementation. (See FlexchartMVVM_Mod.zip)
Thanks & Regards,
Aastha
