Posted 16 July 2018, 11:00 am EST
I want to build a combobox with more than one column. For the demoproject I created the columndescription as a static resource, directly in xaml and in codebehind. If you run the project, it looks fine. However, if you uncomment the line 43 up to 45, only one of the tree columns is shown. That is the value from the ToString()-method of the DemoItem-class.
What should I do, to see all columns, if a C1-Theme is applied to the combobox.
Lutz Boscher
