Posted 7 October 2020, 10:29 am EST
I am binding my class object as ItemsSource to C1DockGroup controls. It throws error immediately after adding one new item in collection. Please find the below xaml code and class object.
XAML Code:
<c1:C1TabControl x:Name=“TabControl” Grid.Column=“1” ItemsSource=“{Binding TabVisualizers}” TabItemClose=“InEachTab”
SelectedItem=“{Binding SelectedVisualizerTab,Mode=TwoWay,UpdateSourceTrigger=PropertyChanged}” AllowDrop=“True”>
c1:C1TabControl.ItemTemplate
</c1:C1TabControl.ItemTemplate>
c1:C1TabControl.ContentTemplate
<c1:C1DockControl x:Name=“dockControl” Grid.Row=“2” AllowDrop=“True” Drop=“DropList_Drop” ItemDockModeChanged=“DockControl_ItemDockModeChanged” PickerLoading=“DockControl_PickerLoading”>
<c1:C1DockGroup ItemsSource=“{Binding TabContents,UpdateSourceTrigger=PropertyChanged}”>
<!–c1:C1DockGroup.ItemContainerStyle
<Setter.Value>
<dockControl:DockTabControl DockMode=“{Binding DockMode,UpdateSourceTrigger=PropertyChanged}” Drop=“DropList_Drop” FilterCommand=“{Binding FilterCommand,UpdateSourceTrigger=PropertyChanged,RelativeSource={RelativeSource Mode=FindAncestor,AncestorType={x:Type Window}}}” MaximizeCommand=“{Binding MaximizeCommand,UpdateSourceTrigger=PropertyChanged,RelativeSource={RelativeSource Mode=FindAncestor,AncestorType={x:Type Window}}}”>
<c1:C1DockTabItem Header=“{Binding TableName,UpdateSourceTrigger=PropertyChanged}”>
</c1:C1DockTabItem> </dockControl:DockTabControl> </DataTemplate> </Setter.Value> </Setter> </Style> </c1:C1DockGroup.ItemContainerStyle>--> <c1:C1DockGroup.ItemTemplate> <DataTemplate> <dockControl:DockTabControl DockMode="{Binding DockMode,UpdateSourceTrigger=PropertyChanged}" Drop="DropList_Drop" FilterCommand="{Binding FilterCommand,UpdateSourceTrigger=PropertyChanged,RelativeSource={RelativeSource Mode=FindAncestor,AncestorType={x:Type Window}}}" MaximizeCommand="{Binding MaximizeCommand,UpdateSourceTrigger=PropertyChanged,RelativeSource={RelativeSource Mode=FindAncestor,AncestorType={x:Type Window}}}"> <c1:C1DockTabItem Header="{Binding TableName,UpdateSourceTrigger=PropertyChanged}"> </c1:C1DockTabItem> </dockControl:DockTabControl> </DataTemplate> </c1:C1DockGroup.ItemTemplate> </c1:C1DockGroup> </c1:C1DockControl> </Grid> </DataTemplate> </c1:C1TabControl.ContentTemplate> </c1:C1TabControl>
Class Object:
public class TabVisualizer
private string _tabName;
private ObservableCollection tabContents;
public string TabName { get => _tabName; set => _tabName = value; } public ObservableCollection<TabContent> TabContents { get { return tabContents; } } public TabVisualizer() { tabContents = new ObservableCollection<TabContent>(); } } public class TabContent : ViewModelBase { private string _tableName; private string _fullName; private C1.WPF.Docking.DockMode _dockMode; private object _dockTabContent; public string TableName { get => _tableName; set => _tableName = value; } public string FullName { get => _fullName; set => _fullName = value; } public DockMode DockMode { get => _dockMode; set { _dockMode = value; RaisePropertyChanged(); } } public object DockTabContent { get => _dockTabContent; set { _dockTabContent = value; RaisePropertyChanged(); } } }
Logic:
private void AddNewTabItem()
var tabVisualizer = new TabVisualizer() { TabName = $“Header {TabControl.Items.Count + 1}” };
TabVisualizers.Add(tabVisualizer);
TabControl.SelectedIndex = TabControl.Items.Count - 1;
private ObservableCollection _tabs;
public ObservableCollection TabVisualizers { get => _tabs; }
private TabVisualizer selectedVisualizerTab;
public TabVisualizer SelectedVisualizerTab { get => selectedVisualizerTab; set { selectedVisualizerTab = value; RaisePropertyChanged(); } }
private void AddContents()
TabContent tabContent = new TabContent();
tabContent.DockMode = DockMode.Docked;
tabContent.FullName = nodeResult.NodeName;
tabContent.TableName = nodeResult.NodeName;
SelectedVisualizerTab.TabContents.Add(tabContent);
Thanks and Regards,
Vinoth Kumar Ravi
