Posted 16 May 2022, 4:43 am EST
is it possible with the C1DragDropManager beetween two DataGrid that I can insert somewhere the new row?
And also highlight the selected row (target)
Forums Home / ComponentOne / WPF Edition
Posted by: patrick.muellner on 16 May 2022, 4:43 am EST
Posted 16 May 2022, 6:48 am EST
Hi Patrick,
Yes you can implement this requirement using C1DragDropManager. I have attached a sample which implements the same using C1DragDropManager’s RegisterDropTarget/RegisterDragSource/UnRegisterDragSource methods and DragDrop event. (see DataGridDragDrop.zip)
Note: The attached sample implements one way drag drop i.e. from one DataGrid to other. You can use the same implementation for vice versa.
Posted 24 May 2022, 3:30 am EST
thanks for you answer.
But is it possible that I insert the row where I drag over?
And also the row is selected where I want to drop it?
Posted 24 May 2022, 4:32 am EST
Additional - with DragDropManager possible that I can use this with more rows?
Posted 24 May 2022, 6:10 am EST
Hi Patrick.
Thanks for reaching out to us again.
The sample provided in previous post is the example to drag a row and insert into another Datagrid. Could you please clarify your requirement. What you want to achieve? Row insertion while drag/drop solution is already provided with you.
In order to select a row where you want to drop a dragged row. You need to handle DragOver event as:(see code snippet)
private void _dragDropManager_DragOver(object source, DragDropEventArgs e)
var targetDataGrid = e.DropTarget as C1DataGrid;
var cell = targetDataGrid.GetCellFromPoint(Mouse.GetPosition(this));
if(cell != null)
targetDataGrid.Selection.Clear();
targetDataGrid.Selection.Add(new DataGridCellsRange(cell.Row));
private void Source_PreviewMouseDown(object sender, MouseButtonEventArgs e)
var cell = sourceDataGrid.GetCellFromPoint(e.GetPosition(null));
if (cell != null && cell.IsSelected)
draggedData.Clear();
foreach (User item in sourceDataGrid.SelectedItems)
draggedData.Add(item);
_dragDropManager.DoDragDrop(cell.Row.Presenter, e, DragDropEffect.Move);
e.Handled = true;
// On Drop
private void OnDragDrop(object source, DragDropEventArgs e)
if(cell!=null)
int index = cell.Row.Index;
foreach (User item in draggedData)
(sourceDataGrid.DataSourceView.SourceCollection as ObservableCollection<User>).Remove(item);
(targetDataGrid.DataSourceView.SourceCollection as ObservableCollection<User>).Insert(index, item);
index++;
targetDataGrid.Selection.BeginUpdate();
targetDataGrid.Selection.Add(targetDataGrid.Rows[cell.Row.Index - draggedData.Count], targetDataGrid.Rows[cell.Row.Index - 1]);
targetDataGrid.Selection.EndUpdate();
Please refer the attached modified sample for the same : DataGridDragDrop_Mod.zip
Nitin
Posted 11 November 2022, 10:01 am EST
I have one additional question.
What I have many rows und want do drop them for example to the bottom of my DataGrid the Sroller doesn’t works.
So with many rows it is not possible? How can I solve this problem?
Regards Patrick
Posted 14 November 2022, 3:03 am EST
Hi Patrick,
Apologize for the delay in response.
To scroll target DataGrid while dragging, you need to handle MouseMove event of the current window as:(see code sippet)
private void TargetGrid_MouseMove(object sender, MouseEventArgs e)
if (e.MouseDevice.LeftButton == MouseButtonState.Pressed)
var ht = targetDataGrid.GetCellFromPoint(e.GetPosition(this));
if (ht != null)
if (targetDataGrid.Viewport.LastVisibleRow == ht.Row.Index && targetDataGrid.Rows.Count - 1 > ht.Row.Index)
targetDataGrid.ScrollIntoView(ht.Row.Index + 1, ht.Column.Index);
if (targetDataGrid.Viewport.FirstVisibleRow == ht.Row.Index && ht.Row.Index > 0)
targetDataGrid.ScrollIntoView(ht.Row.Index - 1, ht.Column.Index);
Please refer the attached modified sample for the same : DataGridDragDrop_Mod2.zip
Nitin
