C1Flexgrid datamap is not working properly
Posted by: ahmdsalh on 26 July 2018, 2:14 am EST
    Posted 26 July 2018, 2:14 am EST
    I’m using c1flexgrid in winform (Vb.net) that i populate using sqldata reader, i have a a problem in data mapping when the column datatype is byte (tinyint in sql) where the datamap is never executed despite the fact that other columns of type integer or bit has the datamap executed properly.
    What can i do?
    Thanks in Advance
  • Posted 27 July 2018, 7:20 am EST - Updated 4 October 2022, 9:17 am EST
    Could you please share the code you are using for DataMapping the byte column, because the DataMap seems to be showing properly at my end. Do let me know, if I’m missing anything here.
    See attached images. Also, attached is sample application for your reference.
    Ruchir
    C1FlexGrid_Byte.zip
