Posted 19 July 2019, 6:23 am EST
I am having an issue with C1Flexgrid (v4.0.20153.497) where I have a column header with a large text. This text is not fully shown(starting and ending characters are getting cut off). After searching, I found that I can use “AutoSizeColumns” to fix the cut-off issue by passing an appropriate value to the parameter named ‘extra’. It worked in the begining. But when I added more text to my large column header to make it even larger, it again started cutting off some part and I had to go back and increase the value of ‘extra’ parameter to fix it further.
Is there a way so that I do not have to keep modifying ‘extra’ parameter based on the size of my column header text?
I have attached my sample project. If you add more text to the ‘longColHeader’ you also have to modify the ‘extra’ in the Flexgrid_LayoutUpdated() event in the sample project.
Anil
C1FlexgridTest(Col headers is cut-off).zip
