Posted 9 March 2018, 5:51 pm EST
I am using C1FlexGrid and I have a read-only data bound column that contains a UTC date time. I want to display that date time in local time. Do you have an example of a way to do that?
Forums Home / ComponentOne / WPF Edition
Posted by: scadavantagesupport on 9 March 2018, 5:51 pm EST
Posted 12 March 2018, 9:12 am EST
Would it be possible for you to convert datetime to LocalTime using .ToLocalTime() method in the get accessor of the property itself(to which you are binding the datetime column) . This seems to work in attached sample application.
Let me know, if I am missing anything here.
Ruchir Agarwal
C1FlexGrid_LocalTime.zip
Posted 12 March 2018, 12:37 pm EST
No, that would not be ideal. I want to be able to have two columns, one showing UTC time the other showing local time. The object I am dealing with is a database entity and only has one timestamp field. I cannot modify the source object. My only other option would be to write a wrapper but that is a lot of overhead I was hoping to avoid.
Posted 13 March 2018, 9:11 am EST
In that case, you may create a Class inheriting from CellFactory and override its CreateCellContent method and translate the value there, as follows:```
public class MyCellFactory : CellFactory
public override void CreateCellContent(C1FlexGrid grid, System.Windows.Controls.Border bdr, CellRange rng)
if(grid.Columns[rng.Column].ColumnName == “LocalTime”)
var date = Convert.ToDateTime(grid.Cells[rng.Row, rng.Column]).ToLocalTime();
TextBlock tb = new TextBlock();
tb.Text = date.ToString();
bdr.Child = tb;
else
base.CreateCellContent(grid, bdr, rng);
public override void DisposeCell(C1.WPF.FlexGrid.C1FlexGrid grid, C1.WPF.FlexGrid.CellType cellType, System.Windows.FrameworkElement cell)
Border bdr = (Border)cell;
bdr.Child = null;
I have modified attached sample application, implementing the above, for your reference.
Let me know, if you have any issues.
Ruchir Agarwal
[zip filename="C1FlexGrid_LocalTimeCellFactory.zip"]public\uploads\cfa478abb6df64feacd923999508d55c1520946666451.zip[/zip]
