Posted 19 April 2021, 2:29 am EST
Hi Mike,
> I have looked and looked and don’t see how to place tab items on the left or right side with horizontal text
C1TabControl displays the tab items text vertically by default when they are docked to left/right. However, You can display text horizontally by applying a LayoutTransform to the C1TabItems as follows:
<Window.Resources>
<local:RotateConverter x:Key="RotateConverter"></local:RotateConverter>
<Style TargetType="c1:C1TabItem">
<Setter Property="LayoutTransform">
<Setter.Value>
<RotateTransform Angle="{Binding RelativeSource={RelativeSource Mode=FindAncestor, AncestorType=c1:C1TabControl}, Converter= {StaticResource RotateConverter}}"></RotateTransform>
</Setter.Value>
</Setter>
</Style>
</Window.Resources>
> Secondly, when a the “New” tab is pressed, which event is fired?
C1TabControl’s SelectionChanged event is fired Whenever a new tab is selected/pressed.
> Thirdly, for the initial tab and subsequent new tabs, how may I specify a standard form to display?
You can set the C1TabItem’s Content property in order to display a form as follows:
<c1:C1TabItem Header="Tab 1">
<c1:C1TabItem.Content>
// Put Form here
</c1:C1TabItem.Content>
</c1:C1TabItem>
Please refer to the same from the attached sample. (see TabControlSample.zip)
