c1TreeView theme problem WPF
Posted by: kyriakos.hadjikyriakou on 16 May 2018, 7:33 am EST
    Posted 16 May 2018, 7:33 am EST
    I use C1Theme and at the time that I apply the theme into main Grid to change the theme in child control then the treeview context magically disappears
    Please anyone help me with that
    Thank you very much
  • Posted 17 May 2018, 7:24 am EST
    Could you elaborate on which grid are you using? And also what is the UI structure of the window, how are ComponentOne’s TreeView and ComponentOne grid (C1DataGrid/ C1FlexGrid) linked.
    I tried with a primitive project consisting of a window with TreeView & C1DataGrid and applied C1Theme to both, the window and C1DataGrid, but did not observe the mentioned issue. See attached application.
    Could you modify it and share back to demonstrate the issue.
    Ruchir Agarwalprj_ThemeTreeView.zip
  • Posted 22 May 2018, 6:03 am EST
    Dear Agarwal,
    I upload my scenario when you can see that I set dynamically the theme into the components.
    All component work perfectly only TreeView control lose there context.
  • Posted 23 May 2018, 1:42 am EST
    I could not find any attachment. Can you please attach it again?
    Singh
  • Posted 24 May 2018, 12:57 am EST
  • Posted 25 May 2018, 3:22 am EST
    I found this issue is related to the below properties and escalated this to dev team. Will let you know as soon as there is any information from them.
    		[b]	 IsVirtualizing="True"
                           ShowLines="True"[/b]
    For the meantime, you can remove these properties from the C1TreeView in your code.
    Hope, it clarifies for you.
    [TFS ID: 323962 for internal use only]
    Singh
  • Posted 23 August 2018, 5:35 am EST
    This issue has been fixed in the latest release build which can be downloaded from the link below:
    http://prerelease.componentone.com/dotnet40/C1WPFLibrary/2018-T2/C1WPFBasicLibrary.4_4.0.20182.595.zip
    You can update to 2018 v2 build using C1Live.
    Pragati
