Change arrows color in TreeView
Posted by: firelex on 5 July 2021, 8:26 am EST
    Posted 5 July 2021, 8:26 am EST
    I’m using C1TreeView from the C1 examples (SimpleC1TreeViewPage).
    When not selected TreeItem and its arrow are dark blue - both good visible on gray background. But on selection happens following:
    • “background gets dark blue”
    • “TreeItem is painted white - still visible”
    • “arrow remains dark blue - gets invisible!”
    How can change color of arrows (collapsed and expanded) in TreeView when the item is selected?
    Thanks in advance.
  • Posted 6 July 2021, 9:01 am EST
    Hi Lex,
    You can implement this requirement by using DataTrigger with ToggleButton’s (present in TreeViewItem template) ControlTemplate as follows:
    <ControlTemplate.Triggers>
                  <DataTrigger Binding="{Binding RelativeSource={RelativeSource FindAncestor, AncestorType={x:Type c1:C1TreeViewItem}}, Path=IsSelected}" Value="True">
                            <Setter TargetName="CollapsedIcon" Property="Fill" Value="Red"/>
                            <Setter TargetName="ExpandedIcon" Property="Fill" Value="Red"/>
                   </DataTrigger>
    </ControlTemplate.Triggers>
    Please refer to the same from the attached modified sample. (see BasicControls_Mod.zip)
  • Posted 7 July 2021, 3:21 am EST
    Thanks, Kartik!
    Just what I needed.
