Custom Contour Levels for C1Chart3D
Posted by: mgriffiths on 14 March 2021, 7:29 pm EST
    Posted 14 March 2021, 7:29 pm EST
    I’m trying to set custom contour levels on the C1Chart3D and I can’t figure out how to make it work. I read that I can use ContourData on the GridDataSeries, but I don’t know what format the data should be in.
    Are there any examples of how to set the ContourData?
    Also should the collection editor work for ContourData and ZData? I was unable to add any data
  • Posted 15 March 2021, 4:01 am EST
    Hi Michael,
    We are sorry but it is not possible to provide custom contour levels in C1Chart3D as it internally calculates the contour levels based on the provided data. However, you can set the contour levels count using the C1Chart3D’s ContourLevelsCount property.
    GridDataSeries’s ContourData property contains the contour value for corresponding ZData. For example, contour value for ZData[1, 2] will be present in Contour[1, 2].
    Please refer to the same from the attached sample. (see Chart3DContour.zip)
    Since there is no editor available for 2D array and hence it won’t be possible to edit the ContourData/ZData properties in designer. JFYI, CollectionEditor supports editing properties of type ICollection.
    Chart3DContour.zip
