Custom grouping in the componentone Flexgrid
Posted by: rambabu on 9 August 2023, 6:10 pm EST
    Posted 9 August 2023, 6:10 pm EST - Updated 9 August 2023, 6:17 pm EST
    I am looking to customize the component one flex grid grouping and customize the group header rows to achieve format similar to the following screenshot
    Can you please provide any sample/documentation to implement this ?
  • Posted 10 August 2023, 2:42 am EST
    Hi Rambabu,
    You can implement custom grouping in the flexgrid by creating custom converters and set them for the PropertyGroupDescriptions of the flexgrid’s collection view. Here is the code snippet for your reference:
    class CountryInitialConverter : IValueConverter
        public object Convert(object value, Type targetType, object parameter, System.Globalization.CultureInfo culture)
            return $"Country name starting with: {((string)value)[0].ToString().ToUpper()}";
        public object ConvertBack(object value, Type targetType, object parameter, System.Globalization.CultureInfo culture)
            throw new NotImplementedException();
    You can refer to the following link for more information regarding the same: *https://www.grapecity.com/componentone/docs/wpf/online-flexgrid/CustomGroupConverters.html
    As per my understanding, you want to consolidate the data from the rows within a group into the columns of the group header row. This requirement can be achieved by setting the Aggregate property of the GridColumn as shown in the following line of code:
    <c1:GridColumn Binding="OrderCount" Width="*" Aggregate="Maximum" />
    Here is the reference link about Group aggregates feature in WPF flexgrid: *https://www.grapecity.com/componentone/docs/wpf/online-flexgrid/GroupTotal.html
    We have attached a sample application for your reference. Please check the “Grouping” tab in the application to check the behavior.
    FlexGridExplorer_Mod.zip
    Thanks & Regards,
    Aastha
  • Posted 11 August 2023, 3:06 pm EST
    Hello Aastha,
    this is okay for editing the text content in the group header, but we need to add the framework elements like an icon in the aggregate column/ group header column.
    please let me know if that is possible.
    Thanks & Regards
    Teja Gudivada
  • Posted 14 August 2023, 3:37 pm EST
    Hi Teja,
    You can show the icons in the cell content of the group row by overriding GridCellFactory’s CreateCellContent and GetCellContentType method as shown in the following code:
    public override object GetCellContentType(GridCellType cellType, GridCellRange range)
        if (Grid.Rows[range.Row] is GridGroupRow groupRow && range.Column == 2 && cellType == GridCellType.Cell)
            return typeof(StackPanel);
        return base.GetCellContentType(cellType, range);
    public override FrameworkElement CreateCellContent(GridCellType cellType, GridCellRange range, object cellContentType)
            StackPanel stk = new StackPanel() { Orientation = Orientation.Horizontal };
            Image iconImage = new Image();
            Uri iconUri = new Uri("pack://application:,,,/Images/Album.png");
            iconImage.Source = new BitmapImage(iconUri); // Load image from Resources folder
            iconImage.Width = 15; // Set desired width
            iconImage.Height = 15; // Set desired height
            stk.Children.Add(iconImage);
            stk.Children.Add(new TextBlock() { Text = Grid[range.Row, range.Column].ToString() , Margin = new Thickness(5, 8, 5, 8)});
            return stk;
        return base.CreateCellContent(cellType, range, cellContentType);
    Kindly refer to the Grouping.xaml.cs file in the attached sample for full implementation. (GroupRowTemplate.zip)
    Thanks & Regards,
    Aastha
  • Posted 17 August 2023, 3:55 pm EST
    Thank you Aastha for providing the solution
