Posted 4 April 2018, 12:50 am EST
Hi Swapnil,
I am sorry but there is no direct property to show/hide the Save button in the toolbar. I have forwarded this as an enhancement request (ID: 316398) to the developers.
As a workaround, you can modify its design template to make the desired changes. For this,
a. Right click on the toolbar within the C1PdfViewer (after drag drop)
b. Select “Edit Template” option from the context menu that appears
c. Then, select “Edit a copy” option
Here, you have to set “Visibility=false” at Save button xaml markup.
Please refer the attached sample implementing the same.
Pragati
Wpf_CustomizeToolbar_C1PdfViewer.zip
