DataGrid Double Click issue
Posted by: abellisomi on 27 October 2020, 1:11 pm EST
    Posted 27 October 2020, 1:11 pm EST
    This issue is related to
    https://www.grapecity.com/forums/wpf-edition/datagrid-double-click-scro
    It happens when I double click on the Filter row.
    However that solution does not seem to work for us. I am using the
    OriginalSource
    to check if the parent is a DataGrid element, however sometimes it is, other times (when I click on empty text in a cell) the Parent is just a regular Windows Grid.
    This is the code I am using:
            private static bool IsDataGridRowEvent(object originalSource)
                var element = originalSource as FrameworkElement;
                while (element != null)
                    if (element.Parent is DataGridCellPresenter)
                        return true;
                    element = element.Parent as FrameworkElement;
                return false;
    Any tip on how make this work? Thank you.
  • Posted 28 October 2020, 2:49 am EST
    As I understand you want to capture mouse double click for a filter row, right? If so, did you try to use the LoadedRowPresenter event? Please check the following code once:
    Code:```
    private void Grid_LoadedRowPresenter(object sender, C1.WPF.DataGrid.DataGridRowEventArgs e)
    e.Row.Presenter.MouseDoubleClick += Presenter_MouseDoubleClick;
    private void Presenter_MouseDoubleClick(object sender, System.Windows.Input.MouseButtonEventArgs e)
    if (e.Source.GetType() == typeof(DataGridRowPresenter))
    //perform your task
  • Posted 28 October 2020, 7:16 am EST
    I want the double click to be fired ONLY for the data rows so not for
    • Filter rows
    • Scrollbars
    • Group rows
  • Posted 29 October 2020, 12:40 pm EST
    Yes, the above should work for this requirement.
    Just in case, the MouseDoubleClick event fires multiple times for each double click, after clicking the scrollbar etc, you may tweak the above code as follows:```
    if (e.Row.Index > 0 && e.Row.Presenter.Tag == null)
    e.Row.Presenter.Tag = “Done”;
  • Posted 10 November 2020, 3:20 pm EST
    Works perfectly thank you!
