Document viewer mising lines in report
Posted by: milosic.bogdan on 14 June 2018, 6:52 am EST
    Posted 14 June 2018, 6:52 am EST
    Im developing application where i use reports created in c1 report designer.
    While generatingg data work as expected, i have problem with displaying lines…
    If i preview report in report designer it show me like i
    n picture reportViewer, but when i display report in program it show me like in picture program
  • Posted 14 June 2018, 6:57 am EST
    It seems that all lines are moved to point 0, 0 in dokument???
    XAML:
    <C1Report:C1DocumentViewer Grid.Row="1" Grid.ColumnSpan="3" x:Name="c1DocumentViewer" Background="{DynamicResource FormBGBrush}">
                <C1Report:C1DocumentViewer.DocumentViewer>
                    <C1Report:C1DocumentViewer IsManipulationEnabled="True"/>
                </C1Report:C1DocumentViewer.DocumentViewer>
            </C1Report:C1DocumentViewer>
    VB code
     rep.Load(fileFullPath, reportName)
    rep.DataSource.ConnectionString = "Provider=SQLOLEDB.1;" & ApplicationSetting.appConSetting.ConnectionStringLmisNETCurrent
    c1DocumentViewer.Document = rep.FixedDocumentSequence
  • Posted 14 June 2018, 7:27 am EST
    I found one way when report work
    rep.PageRenderingMode = PageRenderingMode.AsMetafiles
    But in this case report rendering is low and also i cannot copy text from report if i work that way…
  • Posted 15 June 2018, 5:56 am EST
    Can you please share the report and the sample demonstrating the problem? Please make sure that the sample is working. I would like to investigate this further.
    Pragati
  • Posted 18 June 2018, 7:41 am EST
    Todays update:
    I made one sample program where i added reportviewer window, and everything works ok, lines are shown as expected.
    I also added copy of that window in existing program and i figured that in old program lines are again in top left corner ???
    I checked references an are same in both programs: C1.WPF.C1Report.4
  • Posted 18 June 2018, 8:07 am EST
    Problem solved!!!
    We had some issues with default styles for paths
