Dotnet build license nag screen
Posted by: couturethierry on 14 January 2021, 7:30 am EST
    Posted 14 January 2021, 7:30 am EST
    I am migrating my WPF app from .NET Framework to .NET 5.
    I have a licenses.licx file.
    Everything is working fine when I build my WPF app from within Visual Studio (Build>Rebuild Solution): I have no license nag screen when I run my app.
    Now I need to build my app from command line: dotnet build
    When I do that, I have an issue with LC.exe, this issue is explained here: https://github.com/dotnet/winforms/issues/1462
    So, I tried the workaround detailed here: https://github.com/dotnet/winforms/issues/1462#issuecomment-672640520
    I found the compiled *.licx file in the obj folder: *.dll.licenses, then I removed the *.licx file from my project and added the *.dll.licenses as an EmbeddedResource.
    The dotnet build command now runs successfully, but when I run my app, the license nag screen is displaying.
    I also tried to compile the *.licx file to obtain my *.licenses file from command line, but the result is the same: https://docs.microsoft.com/fr-fr/dotnet/framework/tools/lc-exe-license-compiler
    I need to build my app (.NET 5) from command line and make the C1 license working. How can I achieve that?
    Thank you,
    Thierry
  • Posted 15 January 2021, 7:12 am EST
    Hi Thierry,
    Microsoft has discontinued the ‘licences.licx’ approach for newer platforms (.NET Core). Therefore, if possible you may use C1 controls from Nuget package which uses a build-time license validation model and generates a ‘.gclicx’ file instead of ‘licenses.licx’ file. You can find C1 nuget packages for WPF by name ‘C1.Xaml.WPF.*’
    Just in case required, I have attached a sample for reference. (see LicenseTest.zip)
    Please refer here for more information regarding the new licensing model:
    https://www.grapecity.com/blogs/componentone-2020-v2-licensing-updates
  • Posted 26 January 2021, 9:44 am EST
    Thank you for your answer.
    Unfortunatly my licence is old (C1 2014), and it seems that this version is not available from Nuget.
    But I was finally able to build my .NET 5 app without license issue using the last version of MSbuild, just like before my migration to .NET 5.
  • Posted 27 January 2021, 12:42 am EST
    Hi Thierry,
    I am happy to hear that your issue has been resolved.
