Posted 20 August 2020, 10:04 am EST
I am trying to have two tabs [A,B] that contain a sliding tab [A1, B1] and a main tab with content [A2, B2] each.
<c1:C1DockControl>
<c1:C1DockTabControl >
<c1:C1DockTabItem Header="A" >
<c1:C1DockTabControl DockMode="Docked">
<c1:C1DockTabControl DockMode="Sliding">
<c1:C1DockTabItem Header="A1">
<TextBlock Text="A1" />
</c1:C1DockTabItem>
</c1:C1DockTabControl>
<c1:C1DockTabItem Header="A2">
<TextBlock Text="A2" />
</c1:C1DockTabItem>
</c1:C1DockTabItem>
<c1:C1DockTabItem Header="B" >
<c1:C1DockTabItem Header="B1">
<TextBlock Text="B1" />
</c1:C1DockTabItem>
<c1:C1DockTabItem Header="B2">
<TextBlock Text="B2" />
</c1:C1DockTabItem>
</c1:C1DockTabItem>
</c1:C1DockControl>
A and B are mutually exclusive, as I want the users to be able to flip between their content and see A [A1 slide, A2 dock] or B [B1 slide, B2 dock].
Every time I load this structure though the component breaks with this error:
Stack Trace: System.InvalidOperationException: Specified element is already the logical child of another element. Disconnect it first.
at System.Windows.FrameworkElement.ChangeLogicalParent(DependencyObject newParent)
at System.Windows.FrameworkElement.AddLogicalChild(Object child)
at C1.WPF.C1TabItem.<>c.<.cctor>b__15_0(DependencyObject s, DependencyPropertyChangedEventArgs e)
at System.Windows.DependencyObject.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
at System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
at C1.WPF.C1TabItem.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args)
at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType)
at System.Windows.DependencyObject.SetValueCommon(DependencyProperty dp, Object value, PropertyMetadata metadata, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType, Boolean isInternal)
at System.Windows.DependencyObject.SetValue(DependencyProperty dp, Object value)
at C1.WPF.C1TabControl.PrepareContainerForItemOverride(DependencyObject element, Object item)
at System.Windows.Controls.ItemsControl.MS.Internal.Controls.IGeneratorHost.PrepareItemContainer(DependencyObject container, Object item)
at System.Windows.Controls.Panel.GenerateChildren()
at System.Windows.Controls.Panel.EnsureGenerator()
at System.Windows.Controls.Panel.get_InternalChildren()
at C1.WPF.C1TabControl.UpdateVisualState()
at C1.WPF.C1TabControl.OnAfterApplyTemplate()
at C1.WPF.C1TabControl.OnApplyTemplate()
at C1.WPF.Docking.C1DockTabControl.OnApplyTemplate()
at System.Windows.FrameworkElement.ApplyTemplate()
at System.Windows.FrameworkElement.MeasureCore(Size availableSize)
at System.Windows.UIElement.Measure(Size availableSize)
at MS.Internal.Helper.MeasureElementWithSingleChild(UIElement element, Size constraint)
at System.Windows.Controls.ContentPresenter.MeasureOverride(Size constraint)
at System.Windows.Controls.Grid.MeasureOverride(Size constraint)
at System.Windows.Controls.Border.MeasureOverride(Size constraint)
at C1.WPF.C1LinePanel.MeasureOverride(Size availableSize)
at System.Windows.Controls.Grid.MeasureCell(Int32 cell, Boolean forceInfinityV)
at System.Windows.Controls.Grid.MeasureCellsGroup(Int32 cellsHead, Size referenceSize, Boolean ignoreDesiredSizeU, Boolean forceInfinityV, Boolean& hasDesiredSizeUChanged)
at System.Windows.Controls.Control.MeasureOverride(Size constraint)
at C1.WPF.Docking.C1DockControlPanel.MeasureOverride(Size availableSize)
at System.Windows.ContextLayoutManager.UpdateLayout()
at System.Windows.ContextLayoutManager.UpdateLayoutCallback(Object arg)
at System.Windows.Media.MediaContext.FireInvokeOnRenderCallbacks()
at System.Windows.Media.MediaContext.RenderMessageHandlerCore(Object resizedCompositionTarget)
at System.Windows.Media.MediaContext.RenderMessageHandler(Object resizedCompositionTarget)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
Exception thrown: 'System.ArgumentOutOfRangeException' in PresentationFramework.dll
Specified argument was out of the range of valid values.
Any idea on how to fix this or how can I achieve the requirements?
Thank you
