Events get unsubscribed after dragging of tabcontrol
Posted by: vinothkumar.r2210 on 13 May 2020, 10:11 am EST
    Posted 13 May 2020, 10:11 am EST
    I have added one button in DockTabControl ControlTemplate.In the loaded event of DockTabControl i have assigned click event for that button. When clicking, click event got executed. After dragging of DockTabControl, click event is not fired.
    private void DockTabControl_Loaded(object sender, RoutedEventArgs e)
    var tab = (DockTabControl)sender;
    if (tab != null)
    Button filterButton = FindChild(tab, “FilterButton”);
    if (filterButton != null)
    filterButton.Click += FilterButton_Click;
        private void FilterButton_Click(object sender, RoutedEventArgs e)
            FilterExecutedEventArgs filterExecutedEventArgs = new FilterExecutedEventArgs("Test");
            FilterEventHandler filterEventHandler = FilterExecutedEvent;
            if(FilterExecutedEvent != null)
                FilterExecutedEvent(sender, filterExecutedEventArgs);
    Thanks and Regards,
    Vinoth Kumar Ravi
  • Posted 14 May 2020, 8:53 am EST
    Hi Vinoth,
    This is expected. When you drag the DockTabControl out of DockControl, the items of DockControl change, That is, before dragging the C1DockControl.Items would have a child (like DockGroup) and this child will further contain the DockTabControl in Item’s collection, but as soon as you float the DockTabControl, its parent changes as it becomes a direct child of DockControl.
    So, you should keep track of DockControl Items and add handler to the DockTabControl that has the specific name.
    Ruchir
  • Posted 15 May 2020, 2:04 am EST
    Hi Ruchir,
    Thanks for the reply. The i have to assign handlers to controls whenever DockControl ItemDockModeChanged.
    Thanks and Regards,
    Vinoth Kumar Ravi
