Flexgrid GroupRow ConverterCulture
Posted by: kisar on 19 January 2021, 7:08 am EST
    Posted 19 January 2021, 7:08 am EST
    Hi, using the flexgrid
    is it possible use the same ConverterCulture setting used in the columns
    for the grouprows
    StringFormat=‘N2’, ConverterCulture={x:Static glob:CultureInfo.CurrentCulture}}
    Thanx
  • Posted 21 January 2021, 4:23 am EST
    Hi Kisar,
    Do you want to set the converter culture for the GroupHeader or GroupAggregate? In case it is GroupHeader then you can use FlexGrid’s GroupHeaderConverter property as follows:
    public class GroupHeaderConverter : IValueConverter
            public object Convert(object value, Type targetType, object parameter, CultureInfo culture)
                var col = value as CollectionViewGroup;
                return $"{col.Name}, {col.ItemCount.ToString("N2", CultureInfo.CurrentCulture)}"; // returning content displayed in group header
            public object ConvertBack(object value, Type targetType, object parameter, CultureInfo culture)
                throw new NotImplementedException();
    // Usage
    flexGrid.GroupHeaderConverter = new GroupHeaderConverter();
    JFYI, GroupAggregates by default uses the same settings specified for the Column.
  • Posted 21 January 2021, 6:05 am EST
    Hi, i meant GroupAggregates but it does not work for me,
    i attached a screenshot where you can see the difference.
    In the xml :
    <c1:Column Width=“100” Binding=“{Binding krecord_base.kdisplay_amount_invoice, StringFormat=‘N2’, ConverterCulture={x:Static glob:CultureInfo.CurrentCulture}}” GroupAggregate=“Sum”>
    In the code :
    var gr = new C1.WPF.FlexGrid.GroupRow();
    gr.Background =System.Windows.Media.Brushes.LightGray;
    gr.FontSize =KAppResources.ksystem__font_size__minus02;
            flexgrid.ColumnFooters.Height      =18;
            flexgrid.ColumnFooters.Background  =System.Windows.Media.Brushes.Black;
            flexgrid.ColumnFooters.Margin      =new System.Windows.Thickness(2,2,0,2);
            flexgrid.ColumnFooters.Rows.Add(gr);
    Thanx
  • Posted 22 January 2021, 4:17 am EST
    Hi Kisar,
    Thank you for sharing the sample code.
    I am able to reproduce this behavior at my end. This seems like a bug so I have escalated it to the devs and will revert back to you when there is any update. [Internal Tracking Id - C1XAML-26843]
    However, until then you can override the GroupRow’s GetDataFormatted method as workaround as follows:
    public class GroupRowEx : GroupRow
          public override string GetDataFormatted(Column col)
                var data = base.GetDataRaw(col);
                return string.Format(col.Binding.ConverterCulture, "{0:"+ col.Binding.StringFormat +"}", data);
    // Usage
    var gr = new GroupRowEx();
    flexGrid.ColumnFooters.Rows.Add(gr);
  • Posted 22 January 2021, 9:21 am EST
    Thanx,
    i have one more question about GroupAggregates,
    if i delete one or more row it does not update the “sum” or “count” or…
    is there something can allow to update it?
  • Posted 25 January 2021, 1:45 am EST
    Hi Kisar,
    It seems like you are removing rows using the FlexGrid.Row’s Remove/RemoveAt methods which only removes the rows from the UI and not from the underlying source. Therefore, you have to use FlexGrid CollectionView’s Remove/RemoveAt method for removing rows from FlexGrid as follows:
    (flexGrid.CollectionView as ListCollectionView).RemoveAt(1);
  • Posted 25 January 2021, 4:40 am EST
    HI,
    in my case i delete the records from viewmodel
    Thanx
  • Posted 27 January 2021, 3:30 am EST
    Hi Kisar,
    Are you using a List as FlexGrid’s ItemsSource? FYI, list doesn’t provide any notification when any item is added/removed. Therefore, I would recommend you to use an ObservableCollection instead or you can use any collection which implements INotifyCollectionChanged interface.
    In case if this doesn’t resolves your issue then I would like to request a small sample application replicating this behavior along with the C1 version you are using.
