FlexGrid refresh
Posted by: info on 15 May 2022, 4:35 am EST
    Posted 15 May 2022, 4:35 am EST
    Hello.
    How to refresh the FlexGrid’s View?
    Does the Refresh Method works?
    In this xaml, FlexGrid refresh works.
    <Window>
    <Grid>
     <c1:FlexGrid></c1:FlexGrid>
    </Grid>
    </Window>
    But in my project, FlexGrid refresh doesn’t work in XAML like:
    <TabItem>
        <c1:FlexGrid>
        </c1:FlexGrid>
    </TabItem>
    (I use the Entity Framework. When an entity reloaded , I want the FlexGrid View to be updated.)
    If the refresh method should be works in this XAML, I’ll create a minimal project for validation.
    C1.WPF.Grid.Ja 6.0.20221.218
  • Posted 16 May 2022, 1:00 am EST
    Thank you for sharing the code snippet.
    Yes you are right FlexGrid’s Refresh method needs to be used in order to refresh the view. However, we couldn’t replicate this behavior at our end in both scenarios. (see FlexGridRefresh.zip)
    So, could you please share a small sample replicating this behavior?
    FlexGridRefresh.zip
  • Posted 16 May 2022, 6:53 pm EST - Updated 4 October 2022, 8:28 am EST
    Thank you for your reply.
    I have created a sample.
    I found the following.
    • “TabItem is irrelevant.”
    • “Behavior is different between 1 row and 2 rows”
    • “Behavior is different depending on whether to sort or not”
    The following code seems to be the cause.
    <c1:GridColumn.CellTemplate>
        <DataTemplate>
            <TextBlock VerticalAlignment="Center" Text="{Binding Path=Text1}" />
        </DataTemplate>
    </c1:GridColumn.CellTemplate>
    202205FlexGridStudy.zip
  • Posted 17 May 2022, 5:57 am EST
    Thanks for the sample and snapshot reference.
    We have replicated this behavior at our end. CellTemplate is not updating properly after invoking Refresh() method. This seems like a bug. So, that we have escalated this behavior to the development team.
    We will get back to you once we have any update from them. [Internal Track Id - C1XAML-29456]
    Nitin
  • Posted 17 May 2022, 6:17 am EST
    Thank you!
    I will wait for the fix.
  • Posted 4 August 2022, 11:06 am EST
    We are happy to inform you that, this issue is fixed in 2022v2 release.
    Please download the latest ComponentOne Control Panel from https://www.grapecity.com/componentone/download and install the latest 2022v2 build.
    Nitin.
