Posted 19 March 2018, 7:09 am EST
I have the following situation:
I have a FlexGrid which is filled with several Data. Each row contains the data ob one object with information for name, timestamp, unit etc. One property of this object is a list of strings. This list of string is filled dynamically in an other view out of a list of proposals. So the following is a possible layout of the list:
- Item1 | “Var A” | 19.03.2018 | V | string A
string B - Item2 | “Var B” | 19.03.2018 | V | string B
string C - Item3 | “Var C” | 19.03.2018 | V | string A
string C - Item4 | “Var D” | 19.03.2018 | V | string A
string B
string C
The problem for this is now, that the default filter of FlexGrid can not filter on the items in the string list. When I add the data as one string, each combination is a separate entry in the values list. If I add it as a list and change the layout of this cell to a listview for example, the value in the filter is just “System.Generic.IEnumerable”.
What I want to accomplish is a Filter like in Excel, where each entry is a separate value inside of the filter view and when I select “string C”, then only Item2, 3 and 4 are shown.
Is there any way to accomplish this with a custom filter for example? Or can I add the date to the list in a different way, that will solve this out of the box?
Thanks for your help!
Eike
