FlexGrid (WPF): Column Binding in Codebehind is NOT effective
Posted by: trancuong200495 on 7 May 2018, 6:15 am EST
    Posted 7 May 2018, 6:15 am EST
    Dear C1 Support Team
    Because my requirements I need dynamic generate column in code behind, and moreover It has Binding Converter, ConverterParameter. So I do it as below but it NO call to Converter when generate column. I spent much time to debug and found solution but I can’t . Could you to see and Show me any wrong. I am so appreciate !
    private static void ColumnsSourceChanged(DependencyObject d, DependencyPropertyChangedEventArgs e)
    C1FlexGrid grid = d as C1FlexGrid;
    if (grid == null || e.NewValue == null) return;
            IEnumerable<IHeaderCell> cols = e.NewValue as IEnumerable<IHeaderCell>;
            if (cols == null) return;
            int num = 0;
            foreach (IHeaderCell col in cols)
                Column gridViewColumn = new Column();
                if (!string.IsNullOrEmpty(col.CellConverterKey) && grid.Resources.Contains(col.CellConverterKey))
                    var binding = new Binding();
                    binding.Converter = grid.Resources[col.CellConverterKey] as IValueConverter;
                    binding.ConverterParameter = col;
                    gridViewColumn.Binding = binding;
                if (col.CellTemplateKeySelector != null)
                    string cellTemplateResourceKey = col.CellTemplateKeySelector(null);
                    if (grid.Resources.Contains(cellTemplateResourceKey))
                        gridViewColumn.CellTemplate = grid.Resources[cellTemplateResourceKey] as DataTemplate;
                grid.Columns.Add(gridViewColumn);
                ++num;
  • Posted 8 May 2018, 1:06 am EST
    If I generate column in code behind and then set both Binding and CellTemplate, Binding is not effective, if I only add binding it operate ok ? why?
  • Posted 8 May 2018, 3:13 am EST
    If you wish to dynamically set CellTemplate, Binding Converter, ConverterParameter in code-behind, then I would suggest you to use CellFactory. CellFactory consists of various methods, any of which can be overridden. I have attached a demo application ‘DynamicImages’ setting Converter etc for choosen columns.
    In case you wish to do that in XAML, then for that also I have attached a sample ‘ConditionalFormatting’ setting Binding Converter, ConverterParameter etc in xaml.
    Also, for learning more about C1FlexGrid in WPF, I suggest you to refer various product samples installed at ‘\Documents\ComponentOne Samples\WPF\C1.WPF.FlexGrid\CS
    Ruchir Agarwal
    ConditionalFormatting.zip
    DynamicImages.zip
