FlexReportDesigner with SQLite
Posted by: connellyj on 11 January 2018, 4:05 pm EST
    Posted 11 January 2018, 4:05 pm EST
    I am trying to use a SQLite datasource. I have installed the 32-bit ADO.net provider for SQLite (sqlite-netFx46-setup-bundle-x86-2015-1.0.106.0.exe). But in the 32-bit FlexReportDesigner the SQLite Data Provider is greyed out. I have been using SQLite in my Visual Studio application so it is working on my machine. Is there something else I need to do for the FlexReportDesigner ?
  • Posted 12 January 2018, 5:57 am EST
    In order to resolve this issue, I would request you to follow the steps given below:
    1. Uninstall current version of System.Data.SQLite.
    2. Reboot the system.
    3. Download sqlite from:
      https://system.data.sqlite.org/downloads/1.0.103.0/sqlite-netFx40-setup-bundle-x64-2010-1.0.103.0.exe
    4. Install it, please note, during installation ensure that “install assemblies into gac” option is checked.
    5. On 64bit system you have two machine config files:
      C:\Windows\Microsoft.NET\Framework64\v4.0.30319\Config\machine.config and C:\Windows\Microsoft.NET\Framework\v4.0.30319\Config\machine.config​
      find the below mentioned tag of both the files.
    <system.data>
            <DbProviderFactories>
                     <!--add tag here-->
            </DbProviderFactories>
    </system.data>​
    and add this option:
    <add name="SQLite Data Provider" invariant="System.Data.SQLite" description=".NET Framework Data Provider for SQLite"                type="System.Data.SQLite.SQLiteFactory, System.Data.SQLite, Version=1.0.103.0, Culture=neutral, PublicKeyToken=db937bc2d44ff139" />
    It will enable you to use SQLite in FlexReport.
    ~Pragati
  • Posted 15 January 2018, 10:19 am EST
    Awesome! Thanks, it works.
    Now… My solution is 11 VB.net projects using .net 4.5 and x86 . The reporting is all done in one of the projects. I am trying to migrate from C1Report to C1FlexReport. I have added all the references listed in the documentation and I have deleted references to C1Reports. My toolbox does include C1FlexReport, C1FlexViewer, C1FlexViewerPane, and C1FlexViewerDialog. I can add the C1FlexReport but none of the others will drop on my form.
    These are my C1 references:
    Did I miss something? is there a step to the process that I missed?
    Thanks!
  • Posted 16 January 2018, 5:58 am EST
    I am glad to know that it worked.
    Your question has been answered here:
    https://www.grapecity.com/en/forums/winforms-edition/trouble-adding-c1flexviewe
    ~Pragati
