Getting exception when we drag & drop C1DockTabControl
Posted by: vinothkumar.ravi on 12 May 2021, 5:35 am EST
    Posted 12 May 2021, 5:35 am EST
    I am getting below exception when I drag and drop C1DockTabControl.
    Please find the attached stack trace of exception.
    System.ArgumentOutOfRangeException: Index was out of range. Must be non-negative and less than the size of the collection.
    Parameter name: index
    at System.ThrowHelper.ThrowArgumentOutOfRangeException(ExceptionArgument argument, ExceptionResource resource)
    at Syncfusion.Windows.Controls.Cells.VirtualizingCellsControl.RenderVerticalLines(DrawingContext dc, VisibleLinesCollection visibleRows, VisibleLinesCollection visibleColumns)
    at Syncfusion.Windows.Controls.Cells.VirtualizingCellsControl.RenderCellBorders(DrawingContext dc)
    at Syncfusion.Windows.Controls.Grid.GridControlBase.RenderCellBorders(DrawingContext dc)
    at Syncfusion.Windows.Controls.Cells.VirtualizingCellsControl.RenderCellBorders()
    at Syncfusion.Windows.Controls.Cells.VirtualizingCellsControl.OnRender(DrawingContext dc)
    at System.Windows.UIElement.Arrange(Rect finalRect)
    at System.Windows.Controls.ScrollContentPresenter.ArrangeOverride(Size arrangeSize)
    at System.Windows.FrameworkElement.ArrangeCore(Rect finalRect)
    at System.Windows.Controls.Grid.ArrangeOverride(Size arrangeSize)
    at System.Windows.Controls.Control.ArrangeOverride(Size arrangeBounds)
    at System.Windows.Controls.ScrollViewer.ArrangeOverride(Size arrangeSize)
    at MS.Internal.Helper.ArrangeElementWithSingleChild(UIElement element, Size arrangeSize)
    at System.Windows.Controls.ContentPresenter.ArrangeOverride(Size arrangeSize)
    at System.Windows.Controls.Border.ArrangeOverride(Size finalSize)
    at C1.WPF.C1LinePanel.ArrangeOverride(Size finalSize)
    at C1.WPF.Docking.C1DockControlPanel.ArrangeOverride(Size finalSize)
    at System.Windows.ContextLayoutManager.UpdateLayout()
    at System.Windows.ContextLayoutManager.UpdateLayoutCallback(Object arg)
    at System.Windows.Media.MediaContext.FireInvokeOnRenderCallbacks()
    at System.Windows.Media.MediaContext.RenderMessageHandlerCore(Object resizedCompositionTarget)
    at System.Windows.Media.MediaContext.RenderMessageHandler(Object resizedCompositionTarget)
    at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
    at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
    at System.Windows.Threading.DispatcherOperation.InvokeImpl()
    at MS.Internal.CulturePreservingExecutionContext.CallbackWrapper(Object obj)
    at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
    at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
    at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
    at MS.Internal.CulturePreservingExecutionContext.Run(CulturePreservingExecutionContext executionContext, ContextCallback callback, Object state)
    at System.Windows.Threading.DispatcherOperation.Invoke()
    at System.Windows.Threading.Dispatcher.ProcessQueue()
    at System.Windows.Threading.Dispatcher.WndProcHook(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
    at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
    at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
    at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs)
    at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)
    at MS.Win32.UnsafeNativeMethods.DispatchMessage(MSG& msg)
    at System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame)
    at System.Windows.Window.ShowHelper(Object booleanBox)
    at System.Windows.Window.ShowDialog()
    Thanks and Regards,
    Vinoth Kumar Ravi
  • Posted 12 May 2021, 9:02 am EST
    Hi Vinoth,
    Thank you for sharing the stack trace.
    As I can observe from the stack trace, this exception seems specific to Syncfusion’s control. Could you please try drag/drop in DockingSamples product sample present at location Documents\ComponentOne Samples\WPF\v4.5.2\C1.WPF.Docking\CS and see if it shows the same error?
    In case if the product sample doesn’t show any error then I would request you to share a stripped down sample replicating this behavior.
