Hyperpanel Single-click event
Posted by: mike on 25 April 2021, 11:14 pm EST
    Posted 25 April 2021, 11:14 pm EST
    Hi. I only see a double-click event for the Hyperpanel. Is there a sngle-click event, or is there a way for me to add one?
  • Posted 26 April 2021, 2:23 am EST
    Hi Mike,
    You can use C1HyperPanel’s MouseLeftButtonDown event to capture single click. Please refer to the same from the attached sample. (see HyperPanelClick.zip)
    JFYI, I didn’t found any double click event for C1HyperPanel. So, just in case if the above solution didn’t work then I would request you to share the C1 build number you are using.
    HyperPanelClick.zip
  • Posted 26 April 2021, 10:40 pm EST
    Thank you for the answer and the example.
    In my HyperPanel I have 6 images. In the MouseLeftButtonDown event, how do I know which item was clicked? I looked through the sender and e objects and I don’t see which field or property to check.
  • Posted 27 April 2021, 12:32 am EST
    Hi Mike,
    You can use the MouseButtonEventArgs’s Source property to check which image is clicked. Please refer to the same from the attached modified sample. (see HyperPanelClick_Mod.zip)
  • Posted 27 April 2021, 10:32 pm EST
    Thank you Kartik. In others look at this, for each of my images I named then (Name=“abc”). Then in code I cast MouseButtonEvenArgs.Source to Image and then check the Name property.
  • Posted 28 April 2021, 1:29 am EST
    Hi Mike,
    Yes, you can do the same if it fulfills your requirement.
