Keyboardfocus on calendar control
Posted by: lutz.boscher on 14 February 2019, 3:46 am EST
    Posted 14 February 2019, 3:46 am EST
    At startup I want to set the focus to the calendar control in code behind and after that, the user should navigate through the calendar with the keyboard only.
    I have attached a small sample. After clicking the button, the keyboardfocus is set to the calendar, but the calendar does not response to the arrow-keys. First, I have to click in the calendar control to get the keyboardnavigation working.
    What can we do to navigate inside the calendar without using the mouse?
    Lutz Boscher
    Lutz Boscher
  • Posted 14 February 2019, 3:50 am EST
    The attachemnt was not sent, vwnt thoought it was droped-
    the two files as plain text:
    MainWindowsxaml
    <c1:C1Calendar x:Name=“_cal” Focusable=“True” GotKeyboardFocus=“C1Calendar_GotKeyboardFocus”
    LostKeyboardFocus=“C1Calendar_LostKeyboardFocus” Canvas.Left=“280” Canvas.Top=“120” />
    MainWindow.xaml.cs:
    using System;
    using System.Collections.Generic;
    using System.Diagnostics;
    using System.Linq;
    using System.Text;
    using System.Threading.Tasks;
    using System.Windows;
    using System.Windows.Controls;
    using System.Windows.Data;
    using System.Windows.Documents;
    using System.Windows.Input;
    using System.Windows.Media;
    using System.Windows.Media.Imaging;
    using System.Windows.Navigation;
    using System.Windows.Shapes;
    using System.Windows.Threading;
    using C1Calendar;
    namespace C1Calendar {
    /// Interaktionslogik für MainWindow.xaml
    public partial class MainWindow : Window {
    public MainWindow() {
    InitializeComponent();
    	private void C1Calendar_GotKeyboardFocus(object sender, KeyboardFocusChangedEventArgs e) {
    		Debug.WriteLine("In GotKeyboardFocus");
    		_cal.SelectedDate = DateTime.Today;
    	private void C1Calendar_LostKeyboardFocus(object sender, KeyboardFocusChangedEventArgs e) {
    		Debug.WriteLine("In LostKeyboardFocus");
    	private void Button_Click(object sender, RoutedEventArgs e) {
    		var sucess = _cal.Focus();
    		var focusedElement = Keyboard.Focus(_cal);
    		Debug.WriteLine($"Setting KeyboardFocus to _calendar: {sucess}. Focus has {focusedElement}");
    	private void Button_LostKeyboardFocus(object sender, KeyboardFocusChangedEventArgs e) {
    		Debug.WriteLine("In Button_LostFocus");
  • Posted 15 February 2019, 5:55 am EST
    Hello Lutz,
    For this you need to access the C1CalendarItem present inside C1Calendar and set keyboard focus to it. You may use C1Calendar’s PreviewKeyDown event for this```
    private void Window_Loaded(object sender, RoutedEventArgs e)
    calItem = FindVisualChildren<C1.WPF.Schedule.C1CalendarItem>(_cal).ToList()[0];
    calItem.Focusable = true;
    _cal.Focus();
    private void _cal_PreviewKeyDown(object sender, KeyEventArgs e)
            if (e.Key == Key.Left || e.Key == Key.Right || e.Key == Key.Up || e.Key == Key.Down)
                UIElement keyboardFocus = calItem as UIElement;
                TraversalRequest tRequest = new TraversalRequest(FocusNavigationDirection.Next);
                if (keyboardFocus != null)
                    keyboardFocus.MoveFocus(tRequest);
    Ruchir
    [zip filename="Focus_Calendar.zip"]https://gccontent.blob.core.windows.net/forum-uploads/file-fb1946ee-1402-4d51-a8b6-ca881bb4f8d1.zip[/zip]
