Make FlexGrid.DraggedRow not do its default function
Posted by: ydolapchiev on 23 October 2020, 11:01 am EST
    Posted 23 October 2020, 11:01 am EST
    Greetings,
    I am trying to use the
    DraggedRow
    event for
    FlexGrid
    to do my own custom function, but I cannot make the default function not execute as well. I tried using ```
    e.Cancel = true;
    private void ExpressionGrid_DraggingRow(object sender, CellRangeEventArgs e)
    if (!nowDragging)
    nowDragging = true;
    startingDragRow = e.Row;
    movedItem = expressionList[startingDragRow];
    private void ExpressionGrid_DraggedRow(object sender, CellRangeEventArgs e)
    e.Cancel = true;
    expressionList.Insert(e.Row, movedItem);
    expressionList.RemoveAt(startingDragRow+1);
    foreach (ExpressionEntry item in expressionList)
    item.ID = expressionList.IndexOf(item);
    e.Cancel = true;
    I am rewriting my ```
    ItemsSource
    ``` every time a drag occurs. I would like to either be able to cancel the default function, or alternatively, to write my code to execute after the default function finishes because currently the default move happens last and makes the whole event handler useless.
  • Posted 26 October 2020, 5:09 pm EST
    Can you please try to use C1DragDropManager and handle the ItemsSource task in the DragDrop event. Please refer attached application for drag drop implementation using C1DragDropManager.
    Ruchir
    DraggedRow_WPF.zip
