Multiple versions on developer machine
Posted by: elogsdon on 26 September 2019, 2:21 pm EST
    Posted 26 September 2019, 2:21 pm EST
    Is it possible to install multiple versions on the same developer machine? I would want to run a version for maintaining production code and another for working on the next release.
  • Posted 27 September 2019, 1:21 am EST
    As I understand, you want to have side-by-side installation of two different version of ComponentOne on the same machine.
    In that case, I would like to inform you that it is not possible to install two different version of ComponentOne on same machine. This is because during installation process the older version assemblies/files are replaced with their corresponding new versions. This can adversely mess up your projects.
    However, if you want you can keep all the older assemblies in a separate folder on any location on your machine (for maintaining your production code) and use the default ComponentOne installation path for building application for next release.
    Ruchir
  • Posted 27 September 2019, 9:39 am EST
    Thanks, I’ll give that a shot.
    Eric.
