Posted 4 April 2022, 5:14 am EST
Nitin,
2. Resizing - the C1DockTabControl is not resizable when it is in the collapsed state (DockMode.Sliding) and expanded.
To replicate this issue - in the sample provided - collapse/pin the Left C1DockTabControl - then slide open (do not dock) the Left01 Tab - it is not resizable.
Note: if you redock the the Left C1DockTabControl - this behavior corrects itself. But if you again save the layout and load the layout - this error will reoccur and you will need to redock the C1DockTabControl.
I think this is related to Item 1 above and also to the issue identified in [Internal Tracking Id-C1XAML-28881].
Another bug, I believe related to this same issue can be replicated as follows:
2A. Run the provided sample - collapse/pin the Right C1DockTabControl - you can resize the right edge of the MainC1DockTabControl/Yellow Tab - this should not be resizable along this edge.
Another bug:
6. Tab Selection State - to replicate in the attached sample - run the sample - select the Right 02 Tab - Dock the entire Right C1TabDockControl to any of the Inner Right/Left/Top/Bottom Dock positions - the Right 01 Tab now stays as showing selected when not selected - even after changing the tabs dock location. This will also happen with the Left C1TabDockControl. If you first select any tab other than the first and then dock it to the Inner Right/Left/Top or Bottom Dock positions, the first tab within the C1TabDockControl gets highlighted and stays highlighted as selected. This seems to be related to the previous bug that was fixed [Internal Tracking Id - C1XAML-28770]
