.NET5 FlexGrid Filtering , GridNumericColumn
Posted by: info on 12 September 2021, 7:14 am EST
    Posted 12 September 2021, 7:14 am EST - Updated 4 October 2022, 8:39 am EST
    Hello.
    C1.WPF.Grid.Ja 5.0.20212.110
    I have two questions.
    1. How to set the filtering on c1:GridColumn?
    2.How to set Null on c1:GridNumericColumn?
    FlexGridStudyNet5.zip
  • Posted 14 September 2021, 1:27 am EST
    Thank you for providing snapshots and sample.
    1. Filter appears on the basis of Bounded property. You have not bind the column with any property. That’s why Filter isn’t appears. You need to set Binding on Column as: (see code snippet)
    <c1:GridColumn
                        MaxWidth="500"
                        AllowSorting="True"
                        Header="Text"
                        Binding="Text"
                        SortMemberPath="Text">
    </c1:GridColumn>
    1. In order to accept null on GridNumericColumn while editing. You need to handle PrepareCellForEdit event as : (see code snippet)
            private void Prepare_Cell(object sender, GridCellEditEventArgs e)
                if (e.Editor is C1NumericBox)
                    C1NumericBox editor = (e.Editor as C1NumericBox);
                    editor.AllowNull = true;
                    var gridValue = (sender as FlexGrid)[e.CellRange.Row, e.CellRange.Column];
                    if (gridValue == null)
                        editor.Value = double.NaN;
                    else
                        editor.Value = (double)gridValue;
    Please refer the attached sample for the same : FlexGridStudyNet5_Mod.zip
    Nitin
  • Posted 14 September 2021, 8:06 am EST
    Thank you for your help.
