.NET5 FlexGrid: Freezing Columns does not render the divider line
Posted by: frugamas on 1 February 2022, 5:18 pm EST
    Posted 1 February 2022, 5:18 pm EST - Updated 4 October 2022, 8:33 am EST
    I working with .net5 version(5.0.20212.112) of the FlexGrid and I’m having trouble dynamically changing the FrozenColumns.
    If the FlexGrid is opened with 0 columns frozen and then change the FrozenColumn to 1 the divider line does not render. If I resize the window, the line displays.
    If the FlexFrid is opened with 1 column frozen, it renders the divider properly and the changing the number works fine.
    Is there a way to refresh the UI so the divider line displays?
    Felix
    Animated GIF of a modified FlexGridExplorer to show the issue.
  • Posted 2 February 2022, 3:28 am EST
    we can reproduce the same issue at our end. However, we will check more on it.
    For meantime, you can use Measure method of the grid like:
    private void Button_Click(object sender, System.Windows.RoutedEventArgs e)
                FrozenColumns += 1;
                grid.FrozenColumns = FrozenColumns;
                grid.FrozenLinesBrush = new SolidColorBrush(Colors.Red);
                [b]grid.Measure(new System.Windows.Size(grid.ActualWidth, grid.ActualHeight));[/b]
    Hope, it will solve your issue.
    Singh
  • Posted 2 February 2022, 1:01 pm EST
    Thanks. The workaround works. Hopefully it can be resolved natively in later versions.
    Felix
